I'm trying to build a toggle that turns a 4 bit counter on or off. Here's where I'm at so far:
Switch
As you can see, I'm using a single D flip flop. Ideally I want one switch to disable the chip, and another to re-enable it.
Im lost...
Use the clocked output from the switch as the clock to a control flop.
A human pressing a button should be considered a separate clock domain. Therefore, two flops should be used to sync the input for CDC (Clock Domain Crossing). More about CDC here.
Since you have/want two independent inputs, you'll need to use a SR latch to store enable state. Since you're using an asynchronous latch, you won't need to debounce the buttons.
  • \$\begingroup\$ This makes more sense... What's the triangle on bottom? \$\endgroup\$ – Amorphous Nov 27 '13 at 4:51
  • \$\begingroup\$ @Amorphous: That would be your ground connection. \$\endgroup\$ – Ignacio Vazquez-Abrams Nov 27 '13 at 4:58
  • \$\begingroup\$ Hmmm.... Why would you ground your buttons? \$\endgroup\$ – Amorphous Nov 27 '13 at 5:05
  • \$\begingroup\$ @Amorphous: 1) So that the inputs don't float. 2) So that you can detect the transition to V+ when they're pressed. \$\endgroup\$ – Ignacio Vazquez-Abrams Nov 27 '13 at 5:12
To use the D-FlipFlop as a toggle switch, you need to convert it to work as T-FlipFlop. To do the conversion, connect the Q~ (pin 6) to the D input (pin 2). Change the switch S2 from D to CP (pin 3). That should turn the counter on/off in the present configuration.
    \$\begingroup\$ This doesn't work in practice. The switch contacts will "bounce" when pressed or released, giving you many edges on the clock and causing the FF to end up in a random state. \$\endgroup\$ – Joe Hass Nov 27 '13 at 12:59
