11
I have a cell phone battery that has the following written on one side:
  • 3.7 V 1000mAh
  • Limited charge voltage: 4.2 volts
I understand that the first line means, that the battery will always give 3.7V (at least in theory) at its output terminal. Also the battery will last for 1 hour if the mobile circuitry draw 1000mA.
The second line means that under no circumstances I should increase the input charging voltage beyond 4.2V, else it might damage the battery.
Is my understanding correct? If I am correct I would like to know for this battery what is the minimum required voltage for charging?
5 Answers 5
14
Technically the minimum amount of voltage for charging will be anything above the current state of charge. But that's probably not the answer you're looking for, from Lithium-ion battery on Wikipedia:
Lithium-ion is charged at approximately 4.2 ± 0.05 V/cell except for "military long life" that uses 3.92 V to extend battery life. Most protection circuits cut off if voltage greater than 4.3 V or temperature greater than 90 °C is reached. Below 2.50 V/cell the battery protection circuit may render the battery unchargeable with regular charging equipment. Most battery circuits stop at 2.7–3.0 V/cell.
So to achieve a full state of charge you'd normally want to aim at 4.2V. In practice charging Li-Ion safely and efficiently does involve quite a few steps so you may want to look at a dedicated charger chip. You'd need to check the datasheets for any that look of interest but many will operate properly with a supply voltage only a little above 4.2V.
The 3.7V above sounds like the nominal voltage which is the area where the battery will spend most of it's time during the charge to discharge cycle. But they will start out at around 4.2V and drop to a voltage below that. Letting them drop in voltage too far will cause problems, but you'll get some useful life below 3.7V as well.
To safely charge a lithium ion battery, you need to follow the correct charging procedure, which involves a constant-current phase followed by a constant-voltage phase. If you just use a constant-voltage source, you'll end up charging the battery faster than it's designed to cope with.
For instance, here's a datasheet for one particular model of li-ion battery. To fully charge the battery, you need to eventually get it up to 4.2V. But if you just apply a 4.2V across it when it's completely discharged, you'll be putting 4.2V-2.75V=1.45V across a 130mOhm impedance. That means the charging current will be on the order of 10 amps, which is much higher than the battery is rated for. It's specified with a maximum charging rate of "1C" or enough current to fully charge the battery in one hour, which in this case is 1.1A.
You need to actively limit the charging current by reducing the voltage, until the battery is sufficiently charged to self-limit. If you can't find a datasheet for the exact model of battery that you're using, you should err on the side of caution and charge it very slowly. Lithium-ion batteries are prone to catching fire or exploding if abused.
  • \$\begingroup\$ This is a good technical answer, but additionally some Li batteries, particularly some phone batteries already incorporate a tiny PCB with chips that implement the above procedure/algorithm, so the charger can be dumber in that case. \$\endgroup\$
    – Fizz
    Dec 7, 2014 at 20:26
  • \$\begingroup\$ Not that relevant since if the cell is in good shape it will quickly (under 1 min) increase voltage to above 3V. \$\endgroup\$
    – Overmind
    Sep 15, 2016 at 6:05
This is not an area I have much experience in, but I guess it depends on the internal resistance of the battery.
You could try to apply a small charging voltage to the battery, as small as you like, and then measure how much current flows into the battery. If current is flowing into the battery, it should be charging (minus some current which is wasted as heat in the charging process).
The current you can charge the battery with will depend on how charged the battery already is. I.e. if the battery is fully discharged, you can probably charge it with a very small voltage, but if it is almost fully charged, you will need a larger voltage. My intuition tells me that you will have to apply at least 3.7V if you want to charge the battery fully.
Again I am no expert in this area, so above is just my speculation. :)
Taking into consideration the other answers, I will limit my self to just answering the OP questions. 1 - Yes, your understanding is correct.
2 - The minimum voltage required to charge a 3.7v Li-Ion battery (to 3.7v), is 3.7v. A more practical voltage would be, 4.0v (3.7 < 4.0 < 4.2).
A more "realistic" example of the second part of the first sentence would be 10 hours at 100mA.
No, the battery does constantly not give 3.7V. This is the voltage value at a way lower capacity. 3.7V does not means much. That is the value at which the battery is most stable at, but the actual value when fully charged is 4.2V, so a charger will have to provide higher than this if you want to fully charge it.
At 3.3V standard Li-Ion cells are considered discharged because they can no longer provide enough sustained current for the average applications they were designed for.
The minimum voltage for charging a standard Li-Ion is 4.201V. But considering impedances of the charger and cell, most chargers have 4.25 or even 4.3V when running blank (not connected to a cell).
Although those values have been chosen this way they are not like the 10 commandments. You can discharge a cell under 3.3V but it will provide less current and you can charge it even up to 4.3+V and it will have higher capacity, but both practices will lower its lifetime.
So in emergency cases, overcharge them to 4.3V and you'll have some extra capacity to work with and if you want to have a very long time for a cell, let it charge only up to 4V but that will only provide ~80% of the stated capacity.
Getting back to chargers, I'd design my charger like this:
Option 1: 4.0V - safe mode - for safe charging and long life and overdischarged/bad cell recovery.
Option 2: 4.21V - standard - normal charge mode (bad cells with reduced capacity will overheat if charged at standard level)
Option 3: 4.32V - overpower - over-charge mode (lower cell life, very high danger for reduced capacity cells)
  • \$\begingroup\$ I'd recommend reading at least batteryuniversity.com/learn/article/… – if I were to design a Li-Ion cell charger for generic use, I'd target charging up to 4.05-4.10 V only because that will prolong the lifetime of the cell very much. Even charging up to 4.00 V should allow using 70% of the original capacity and the lifetime of the cell should go up 100-500x compared to charging to 100%. It's not an accident that military loads up to 3.92 V only. Note that if you have a battery consisting of multiple cells, you must balance all the cell voltages. \$\endgroup\$ Apr 30, 2021 at 11:39
  • \$\begingroup\$ 4.0-4.1 is indeed good if you need high cycle count. \$\endgroup\$
    – Overmind
    May 17, 2021 at 8:09
