I've started to play with the 555 chip. There is a lot of documentation out there. So I want to create a strobe light project, with an adjustable frequency.
I've played with a lot of capacitors (1nf, 1uf, 10uf, 100uf, 1000uf) and resistances (330ohm, 1kohm, 10kohm, 100kohm, 1mohm). If I can change the frequency, I run into the problem where the light does not stay off for an equal amount of time than it stays on.
For example, right now I have this kind of output when I play with my potentiometer (numbers are not accurate):
  • 100ms on, 100ms off
  • 500ms on, 100ms off
  • 1000ms on, 100ms off
But I'm trying to achieve this kind of scale:
  • 500ms on, 500ms off
  • 1000ms on, 1000ms off
I have multiple 555 chips, but I can't find a way to have the on and off signal to have an equal duration.
  • \$\begingroup\$ I think it is not possible to get a 50% duty with a 555, At least I didn't find to do it when I was in the University, and related books didn't talk about it. It always was >50% or <50%. \$\endgroup\$
    – Chirry
    Nov 28, 2013 at 22:41
    \$\begingroup\$ There are many ways to get 50% duty cycle with a 555. A simple Google search will turn up many examples. The simplest is to connect the timing resistor to the output (pin 3) instead of the usual connection to Vcc via pin 7. \$\endgroup\$
    – Dave Tweed
    Nov 28, 2013 at 23:01
    \$\begingroup\$ @DaveTweed Maybe I just don't use the good keywords, but I've searched all day prior to writing up this question... could you point me to some links on the subject ? Thanks ! :) \$\endgroup\$
    – FMaz008
    Nov 29, 2013 at 10:34
  • \$\begingroup\$ @Chirry: For my application, I don't need a very high precision, could be 45%+55% and it would do just fine. But right now my results are not anywhere close to 50%+50%, more like 95%/5% when at a low frequency. \$\endgroup\$
    – FMaz008
    Nov 29, 2013 at 10:37
  • \$\begingroup\$ @FMazoo8 What I used to do in those cases, is to find a combination of capaticor-resistor that could work in the frequency i need, then with a potenciomenter as resistor I find the resistance it fix better. As you know, it's easier to find resistors than capacitors at a custom value. \$\endgroup\$
    – Chirry
    Nov 29, 2013 at 14:46
Dave Tweed has indicated a simple solution (+1 from me). The circuit for which is...
By charging and discharging the capacitor (C) through the resistance connected to the output (pin 3) the charge and discharge times are the same. By using a fixed resistor (R1) you can set the minimum time for the astable. By adding a variable resistor (VR1) you can easily alter the time without altering the mark/space ratio. The voltage across the capacitor (C) charges and discharges between 1/3 and 2/3rds of the supply voltage set by the internal comparators of the 555. The ON time = OFF time = T = 0.7CR (where R = R1 + VR1) - C in Farads, R in Ohms, T in Seconds.
  • \$\begingroup\$ To be honest I don't understand all the explanation, but I did the circuit and it works way better than the traditional 555 circuit I see all over the Internet (for what I wanted to do). I randomly used a 10K for R1, and tried few Cap for C1 to have the speed that looked OK. (I know, very scientific approach here) The C2 cap seems to be useless, when I remove it, it's working too (?) My setup: C1 = 1uf, R1=10K, VR1=10K potentiometer. Get me a very quick strobe light for visual illusions. \$\endgroup\$
    – FMaz008
    Nov 29, 2013 at 22:54
  • \$\begingroup\$ @FMaz008 C2 stabilizes the thresholds that defines at which voltage the output toggles. You don't want any noise on these voltage levels and that is exactly what C2 does. It filters noise from the reference voltage. \$\endgroup\$
    – jippie
    Nov 30, 2013 at 16:46
  • \$\begingroup\$ Of course this looks very similar to and can also be accomplished with an opamp based relaxation oscillator \$\endgroup\$
    – jippie
    Nov 30, 2013 at 17:06
  • \$\begingroup\$ Not that it was a prerequisite in my original question, but this diagram is impossible to do on a single layer board... Linking pin 6 and 2 is ... not fun. \$\endgroup\$
    – FMaz008
    Dec 4, 2013 at 5:07
    \$\begingroup\$ @FMaz008 Its certainly not impossible but it is an additional question - draw copper track from 6 and 2 and put in a wire link from 8 to 4 under the chip but on other side of board to copper track. \$\endgroup\$ Dec 4, 2013 at 18:05
