I'm playing with ngspice, and wondered if I could get a signal out of a simple RLC circuit using an inductor with initial current. There are no power or current sources. The results aren't what I expect, probably because I did something blatantly stupid and not seeing it.
My .cir file:
simple RLC with initial inductor current
C1  1 0   22uF
L1  1 0   6mH    IC=1A
R1  1 0   10kOhm
.end
Using the ngspice command line,
tran 100us 20ms
plot v(1)
But the plot is flat zero. Why is that?
I expect the voltage at node 1 to increase from 0V at t=0, peak, and continue on as an exponentially decaying sine. My tran timing may be whacky off, but I should see something, maybe just a linear initial rise, or a spike.
  • \$\begingroup\$ try running the analysis for 1 second and see what you get. \$\endgroup\$
    Nov 29, 2013 at 10:25
Found the problem. Need to have "UIC" in the "tran" line.
.tran 50us 30ms 0s  500us UIC
works fine.
Guess I need to spend more time with the spice user manual.
