-2
I hope this question is suitable for this site.
I have an Aiwa NSX-V25. The two speakers attach to the back of the amplifier via free wires that you connect manually.
I want to attach a 3.5mm jack to the wires (each speaker has two) and plug it into my sound output from my computer. Would that work? If so, which wire should I solder to what part of the 3.5mm jack?
closed as off-topic by Nick Alexeev, Chetan Bhargava, PeterJ, Matt Young, jippie Nov 30 '13 at 8:16
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – Nick Alexeev, Chetan Bhargava, PeterJ, Matt Young, jippie
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ off-topic: Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design. \$\endgroup\$ – jippie Nov 30 '13 at 8:16
Computer speakers are usually powered speakers (often known as monitors) - these have an amplifier built in. The inputs are usually line-level.
HiFi Speakers are usually unpowered and have to be connected to the outputs of a HiFi amplifier.
Your Amplifier may have an Aux-in connector to which you can connect an audio cable from your PC's line-out socket. You can purchase cables with suitable connectors at each end.
  • \$\begingroup\$ I actually want to get rid of the amplifier altogether to save space and just get the soundcard output out to the speaker. Is that a possibility? \$\endgroup\$ – Housni Nov 30 '13 at 0:19
    \$\begingroup\$ No, it is not. You need an amplifier. If you are feeling handy, you can put your amplifier inside the speaker if you wish. I also doubt you can solder to a 3.5mm jack directly. They are usually nickel plated. I love this article: en.wikipedia.org/wiki/Solderability \$\endgroup\$ – HL-SDK Nov 30 '13 at 2:55
