For my Circuits II final design project I am given an old transformer that needs to have its power factor corrected to 1 but I am a bit unclear what needs to be done. I'm using this post Power Factor Correction as a reference for power factor information, but I don't really understand it.
Here are the transformer specs:
- 240V to 120 V at 60 Hz
- Single-phase
- Isolated
- Low coupling
- Single primary, dual secondaries
Using a Z-Y Bridge, it was found that Z = (0 + 300j) \$\Omega\$ and Y = (79 + 0j) \$\mu Mhos\$ which are the two measurements I was told were needed. I was also told that an LRC circuit might be the way to go (not sure why exactly). It is noted that the transformer purely inductive to the 60 Hz and therefore (correct me if wrong please) requires a capacitor be placed across transformer to cancel out the inductive reactance. Does this cancellation result in the power factor being 1?
\$ Z_C = \frac{1}{j\omega C} = Z_L = j\omega L = 300j\$ then solve for C? If so, where does the conductance come into play?
My expected layout is one of these three:
