I want to drive a servo rc motor I just purchased, I am a newbie in the electronics world.
I would just like to test out the servo motor first and actually get it to move.
So far I have figured out I need a basic diagram for the circuit, I have consulted the servo motor data sheet, I know I need an oscillator, some transistors, a breadboard and a micro controller, not sure what else yet.
It is possible to drive it without a micro controller right?
I will be using the amicus micro controller.
Any suggestions?
    \$\begingroup\$ A MCU will make it so much easier. Especially if the MCU supports PWM in hardware. \$\endgroup\$ Commented Dec 1, 2013 at 22:10
    \$\begingroup\$ @IgnacioVazquez-Abrams Generating control signals for the R/C servos with a hardware PWM is [arguably] an overkill. \$\endgroup\$ Commented Dec 1, 2013 at 22:17
  • \$\begingroup\$ @NickAlexeev: Then why is analogWrite() so popular? \$\endgroup\$ Commented Dec 1, 2013 at 22:19
    \$\begingroup\$ @IgnacioVazquez-Abrams I don't know why. I don't even know if it is actually popular (being an Arduino function). I was talking about R/C servo control signals. You could have as well asked "why +12V is so popular". ;) \$\endgroup\$ Commented Dec 1, 2013 at 22:27
It is possible. You need to generate a square wave. To change the angle of the servo, you should be able to adjust the pulse width of the wave as well. A simple way to do this is with a 555 timer.
A question like this has already been asked before: What is the simplest way to generate PWM without a Microcontroller?
  • \$\begingroup\$ Thanks for the reply, I'm struggling to know how to actually hook up everything \$\endgroup\$ Commented Dec 1, 2013 at 23:06
  • \$\begingroup\$ There are a lot of suggestions that I have researched, maybe I am making a fuss out of something so simple \$\endgroup\$ Commented Dec 1, 2013 at 23:07
