I am trying to zero in on which home automation protocol to use for my embedded device. I have a wireless module which connects to a router. So the protocol has to operate over wifi. I know I will not be able to use Zigbee and Zwave since these dont operate over the 802.11 layer. I was wondering if there is any open source home automation protocol which is a standard and which has been implemented for wifi or is independent of the medium of transmission of messages ? Also I am targeting embedded systems so if there is a C library to use that someone knows about or a open source project written in C for home automation , please let me know.
\$\begingroup\$ Can you detail a little bit your idea/project ? Also can you give some info about your embedded device ? (type of microcontroller, external memory, etc.) \$\endgroup\$ – zeqL Dec 2 '13 at 16:51
\$\begingroup\$ Note: the reason people use zigbee and zwave is that wifi power consumption is far too high for long-term battery-powered devices. \$\endgroup\$ – pjc50 Jul 2 '15 at 10:22
Since IP is the protocol to rule them all (What is the best wired protocol choice for home automation?),
What about IP6LowPan? Might be a bit of an overkill though.
