I am trying to make LED in MSP430G2 Launchpad keep blinking / off with button like Switch example (http://www.arduino.cc/en/Tutorial/Switch) in Arduino/Energia but I seem to miss something stupid and i don't know what...
const int buttonPin = PUSH2;     // the number of the pushbutton pin
const int ledPin =  GREEN_LED;   // the number of the LED pin
int state = HIGH;      // the current state of the output pin
int reading;           // the current reading from the input pin
int previous = LOW;    // the previous reading from the input pin
// the follow variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0;         // the last time the output pin was toggled
long debounce = 200;   // the debounce time, increase if the output flickers
void setup()
  pinMode(buttonPin, INPUT_PULLUP);
  pinMode(ledPin, OUTPUT);
void loop()
  reading = digitalRead(buttonPin);
  // if the input just went from LOW and HIGH and we've waited long enough
  // to ignore any noise on the circuit, toggle the output pin and remember
  // the time
  if (reading == HIGH && previous == LOW && millis() - time > debounce) {
    if (state == HIGH){
      state = LOW;
    else {
      state = HIGH;
      digitalWrite(ledPin, HIGH);
      delay(100);
      digitalWrite(ledPin, LOW);
      delay(100);
    time = millis();
  digitalWrite(ledPin, state);
  previous = reading;
It blinks once when i press the button. I know that this
or state part messes up. Any help? Thank you.
  • \$\begingroup\$ Your else statement doesn't include anything past the one line below it without brackets. \$\endgroup\$ – Samuel Dec 3 '13 at 21:05
  • \$\begingroup\$ I fixed Else but it still blinks once. \$\endgroup\$ – Cagurtay Dec 3 '13 at 21:16
  • \$\begingroup\$ Where is the loop? \$\endgroup\$ – Brian Drummond Dec 3 '13 at 21:19
  • \$\begingroup\$ I tried to put blink in loop but I don't how to read button inside loop or what to write as loop condition. \$\endgroup\$ – Cagurtay Dec 3 '13 at 21:28
  • \$\begingroup\$ Oh, reading this again, you don't want it to just blink once, you want it to keep blinking until you press the button again? Then try combining arduino.cc/en/Tutorial/BlinkWithoutDelay with the Switch tutorial, maybe with a while or for loop. \$\endgroup\$ – Passerby Dec 4 '13 at 7:43
Is this what you are trying to accomplish?
  • Push-and-release => LED starts blinking
  • Push-and-release => LED turns off
  • and so forth ..
I slightly changed your code to accomplish that. I defined a flag 'blink' that tells the blink routine further down either to blink the LED or to turn it off.
boolean state = HIGH;      // the current state of the output pin
boolean blink = LOW;       // the current mode of the LED either blinking (HIGH) or off (LOW)
void setup()
void loop()
  // the time
  if ( (reading == HIGH) && (previous == LOW) && ((millis() - time) > debounce ) ) {
    blink = !blink;  // invert the current value for the blink flag
    time = millis();
  // if blink flag is HIGH then turn on and off the LED
  // if blink flag is LOW then turn off the LED
  if ( blink == HIGH ) {
    state = !state;   // invert the current state (LOW to HIGH and HIGH to LOW)
    delay(100);
  } else {
  previous = reading;
The disadvantage of this code is that the loop runs slow due to the delay while blinking. The blinker loop can be improved for that behavior, but it introduces a slightly more complex mechanism:
    state = ( millis() >> 8 ) & 1;
  } else {
Here the delay is replaced by making state depend on the number of milliseconds since start, divided by 256 and checking the least significant bit.
| improve this answer | |
  • \$\begingroup\$ Tested on Energia with a Stellaris LaunchPad. \$\endgroup\$ – jippie Dec 3 '13 at 22:11
  • \$\begingroup\$ Just as a note for OP, this code is so simple, there is no difference in using it on a MSP430G2xxx Launchpad or the Stellaris LaunchPad. \$\endgroup\$ – Passerby Dec 4 '13 at 7:59
  • \$\begingroup\$ Thank you! That was what i was trying to do but improved loop doesn't work for me. \$\endgroup\$ – Cagurtay Dec 4 '13 at 10:31
  • \$\begingroup\$ @Cagurtay You are right, I had an old version of the improved loop copied by accident. The correct improved line should read state = (millis() >> 8 ) & 1; \$\endgroup\$ – jippie Dec 4 '13 at 18:12
Else needs an opening curly bracket.
else {
(Error since corrected by OP and Question, but also due to a different interpretation of what OP's vague intentions are (code not working as written vs code not working as intended))
  • \$\begingroup\$ Bah... But still blinks once. \$\endgroup\$ – Cagurtay Dec 3 '13 at 21:07
