Is it possible to wire the LED's in the following way??(shown in the rough diagram of my circuit)
I want the LED's flashing alternatively, ie - D1, D3, D5, D7 (A LED's) are powered by just the transistor and the rest (B LED's) are by the op-amp and transistor (op-amp inverts the signal making it flash alternatively)
The switches are to control the "shutting" of a row and column in order to have just one LED blinking. That is if only LED D3 should be blinking Switch 1 and Switch 2 should be closed, with the rest of the switches open.
my question is: Is it possible to connect the LED's as shown in the figure??
and in order to switch just LED D3 ON, SW1 and SW2 are used, use of SW1 would also switch LED D1 ON, how do i avoid that??
Thanks!
