-1
I bought a portable humidifier from CVS, and it has a SUPER bright LED inside. I've taken it apart and wrapped it in electric tape, and the tape has muted the light, but not 100%. Maybe 80%.
It's possible to remove (read: break) the LED off the PCB, will this cause any other damage? (irregular voltage or something?)
    \$\begingroup\$ Scratch the front of the led with some steel wire kitchen sponge thing, or use a sharpie along with the tape. You could break it off, but without a schematic, we can't tell. And its not a question that will remain open (outside of the scope). Best of luck. \$\endgroup\$
    – Passerby
    Dec 7, 2013 at 4:58
  • \$\begingroup\$ I'd measure the forwarding voltage across the LED when in use, and replace it with no-so-bright LED having about the same voltage. \$\endgroup\$ Dec 7, 2013 at 5:48
  • \$\begingroup\$ A picture is worth a thousand words... and it may compensate for not having a schematic, if the circuit is simple and the traces are in view. \$\endgroup\$ Dec 7, 2013 at 7:51
    \$\begingroup\$ I'd put a small spot of paint over the LED using a cotton-bud. Any opaque paint of any colour should do. I'd let it dry, test and add layers till happy. \$\endgroup\$ Dec 7, 2013 at 10:22
  • \$\begingroup\$ Thanks for the comments. I'll paint + tape it. I didn't know where else to ask, so I went off-topic a bit. Thanks again \$\endgroup\$
    – Pat
    Dec 7, 2013 at 15:13
Not a good idea to try and break an LED off a PCB:
  1. Very high likelihood of damaging the PCB in the process, thus making the device inoperable. Desoldering the LED will take a bit more skill, but lower this risk a bit
  2. Without seeing the schematic for the PCB, it is impossible to tell what other aspects of the device will be adversely affected by the LED being taken out: The designer may have built in dependencies, such that, for instance, calibration of some aspect of the circuit suffers. Less likely than above, but still true
