How to map fpga pins to actual physical pins on the FMC connector on a Zedboard?
Of course I have looked into the user's hardware guide and the master constraint file, but all I have found is a list of the FMC pins out on the FPGA side but nothing on how it is mapped to the LPC FMC pins.
Problem solved. To the googlers out there, though there is no table, you can find this info on the schematics. Check the schematic of the FMC on:
http://zedboard.org/sites/default/files/documentations/ZedBoard_RevD.2_Schematic_130516.pdf
and match the labels with the UCF file.
