The NTE912 contains three standalone BJT transistors and two configured as a differential pair. The datasheet can be found at
http://www.nteinc.com/specs/900to999/pdf/nte912.pdf
and gives a pin configuration that looks like
Short of hooking the chip up and using trial-and-error to see what is the base/emitter/collector, does anyone know how to decipher this pinout?
  • \$\begingroup\$ I'll bet this 912 part has the same transistor arrangement as as a CA-3046. Image here. \$\endgroup\$
    – JYelton
    Commented Dec 10, 2013 at 18:16
according to what I read it is a pin to pin equivalent with CA3086
  • \$\begingroup\$ Ah maybe NTE couldn't use the same pin diagram as Intersil? I notice they pulled some of the introduction wording right from the Intersil datasheet. \$\endgroup\$ Commented Dec 11, 2013 at 16:45
