I'm working my way through the chapter on diodes in Sedra and Smith Fifth Edition
Exercise 3.15 asks:
Consider a diode with \$n=2\$ biased at \$1ma\$. Find the change in current as a result of changing the voltage by \$(a) -20mV (b) -10mv (c)... \$ etc. In each case , do the calculations \$(i)\$ using the small-signal model and \$(ii)\$ using the exponential model.
so for \$(i)\$ we find the diode small-signal resistance with: (page 161.)
\$ r_d = \frac{nV_t}{I_d}\$ with \$V_t = 25mv\$
\$ r_d = \frac{50mV}{1mA}\$
\$ r_d = 50\Omega\$
so then it's simply
\$\Delta I = \frac{\Delta V}{50\Omega}=\frac{-20mV}{50\Omega} = -0.40mA\$
This agrees with the answer given.
For \$(ii)\$, the exponential model:
\$ I = I_S e^{\frac{V}{nV_t}}\$
and as per the book, this can be used to get: (page 150.)
\$\frac{I_2}{I_1} = e^{(V_2-V_1)/nV_t}\$
substituting in the values:
\$\frac{I_2}{1mA} = e^{-20mV/50mV}\$
\$I_2 = 0.67mA\$
this does NOT agree with the book:
the answer given is:
\$0.33mA\$
which can be gotten by
\$0.67mA - 1mA\$
so I think I have made a small mistake, but I have been stuck on this for last two nights so I thought it was time for some help.
All advice is appreciated!!!
