I am trying to interface a 6150 Nokia cellphone with an Arduino Duemilanove board, as some have already done through the FBUS protocol (see here for example).
The FBUS protocol uses 2.8V logic, so I bought Sparkfun's logic level converter to interface with the 5V from the Arduino, right ?
They say:
The level converter is very easy to use. The board needs to be powered from the two voltages sources (high voltage and low voltage) that your system is using. High voltage (5V for example) to the 'HV' pin, low voltage (2.8V for example) to 'LV', and ground from the system to the 'GND' pin.
Thus
HV <-> Arduino 5V
GND <-> Arduino GND
LV <-> ??
GND <-> ??
TXI <-> Phone TX (Low Voltage)
RXO <-> Phone RX (Low Voltage)
TXO <-> Arduino RX (High Voltage)
RXI <-> Arduino TX (High Voltage)
The problem I have is with the low voltage source: there is no power output on the phone.
Can I power the converter LV/GND from another 2.8V source ? Would it be ok with the Arduino 3.3V source ?
