This will be laughably easy for someone who has worked with the dsPIC33 and XC16 compiler, but has already cost me a day. Hopefully someone can save me any more wasted time!
Could someone please tell me what I have done wrong here? All I am trying to do is shut off some LED's using an external interrupt.
/* Device header files */
#include <stdlib.h>
#include <xc.h>
int main(int argc, char** argv) {
// setup internal clock for 80MHz/40MIPS
// 7.37/2=3.685*43=158.455/2=79.2275
CLKDIVbits.PLLPRE=0;        // PLLPRE (N2) 0=/2
PLLFBD=41;                  // pll multiplier (M) = +2
CLKDIVbits.PLLPOST=0;       // PLLPOST (N1) 0=/2
ANSELE = 0x0000; //set all of port B as Digital
TRISE=0xF0;//configures part of port B as output
LATE=0x0F; // writes data to port B
RPINR0= 0x5400;//set pin 1 as interrupt 1
INTCON2 = 0x0000;   /*Setup INT0, INT1, INT2, interupt on falling edge*/
IFS1bits.INT1IF = 0;    /*Reset INT1 interrupt flag */
IEC1bits.INT1IE = 1;    /*Enable INT1 Interrupt Service Routine */
IPC5bits.INT1IP = 4;    /*set low priority*/
//Main Program
while (1);
return (EXIT_SUCCESS);
//_INT1Interrupt() is the INT1 interrupt service routine (ISR).
void __attribute__((__interrupt__)) _INT1Interrupt(void);
void __attribute__((__interrupt__, auto_psv)) _INT1Interrupt(void)
   LATE=0x00; // writes data to port B
   IFS1bits.INT1IF = 0;    //Clear the INT1 interrupt flag or else
   //the CPU will keep vectoring back to the ISR
Thanks in advance!!!
  • \$\begingroup\$ Please give us some more info about your problem/errors \$\endgroup\$ Commented Dec 15, 2013 at 8:48
  • \$\begingroup\$ It compiles fine, loads onto the MCU but it does not detect the interrupt when I bring 0x54 high. \$\endgroup\$ Commented Dec 15, 2013 at 16:38
I see three missing things.
Missing dspic33 number??
AD1PCFGL = 0xFF, or whatever the datasheet tells you, to turn off the adc on those pins, if necessary. ANSEL is for choosing adc input, not turning them into digital.
Input pins TRISXbits.TRISX? = 1, to turn your pin into an input.
  • \$\begingroup\$ Thanks for the reply Erik! Ill give that a shot after work. \$\endgroup\$ Commented Dec 16, 2013 at 18:47
