I'm looking for help and unfortunately stuck for time on a project, so hoping someone wouldn't mind helping me out.
I am trying to calculate the resistor value required for an opto-isolator circuit. I am powering a 24DC magnetic reed switch passing ground through a Siemens SFH615A:
http://docs-europe.electrocomponents.com/webdocs/009c/0900766b8009c194.pdf
Can someone recommend a resistor value, thank you very much.
I have used the calculator available here: http://led.linear1.org/1led.wiz with a 24V supply, 1.5 forward voltage and 60mA forward current.
I would be grateful if someone could double check
  • \$\begingroup\$ What voltage is used to drive the LED - that is what will determine the resistor value. Also, what current is required to operate the reed relay? - that also affects the required LED current. The 60 mA LED current suggested in Alexan_e's answer is the Absolute Maximum rating for the LED, and you should normally use a somewhat lower current where possible. \$\endgroup\$ Commented Dec 19, 2013 at 0:27
The resistor value is calculated like any common LED
$$ R= \frac {V_{in}-ledV_F}{I_{LED}} $$
The actual value depends on the current you want through the LED
For 60mA and typical VF= 1.25v
$$ R= \frac {24v-1.25v}{{0.060A}}$$ which results to about 380 Ohm
If you want to calculate for VF= 1.5v $$ R= \frac {24v-1.5v}{{0.060A}}$$ which results to about 375 Ohm
Peter Bennett made a good point in the comments below about the resistor power rating, make sure it is appropriately sized.
The resistor power is calculated as
$$ P= {I}^2 * R = {0.06}^2 * 380 ohm = 1.368W $$ so a 2W resistor should be good enough
  • \$\begingroup\$ Thanks alexan_e, the standard resistor sizes available to me are 374 Ohm and 390 Ohm, would I be ok with either, thanks. \$\endgroup\$
    – Newbie
    Commented Dec 19, 2013 at 0:03
    \$\begingroup\$ Beware that 22.5V @ 60 mA through a 390 ohm resistor is 1.35 watts! Your standard resistors are probably rated at 1/4 watt or so, so won't survive for long! \$\endgroup\$ Commented Dec 19, 2013 at 0:23
  • \$\begingroup\$ Thanks Peter, yes the calculator recommended 1.4W, thank you for confirming \$\endgroup\$
    – Newbie
