I have configured 2 xbee series 1 modules such that one will receive serial data from any other module of same pan ID and the other will send data to the previous mentioned one.
Now when I use a terminal software (XCTU) to check data transmission its fine. I want to send data serially using a ATMEGA 168 using xbee as transmitter. And another xbee will receive the data and send it to an ATMEGA 2560 based platform. I do not have any platform for atmega 168 so I kinda built a burner (bootloader circuit). The bootloader works. I have connected pin 3 (TXD of USART0) of atmega 168 with data in (pin 3) of xbee module. I have made necessary power connections as well (Vcc=3.3V & GND ). But the xbee does not seem to send anything. Is there something I am missing ? Please help, as you may already figured out I am a complete newbie.
PS : before reducing my reputation please let me know what I am doing wrong so I may rectify that.
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
void uart0_init(void)
 UCSR0B = 0x00; //disable while setting baud rate
 UCSR0A = 0x00;
 UCSR0C = 0x06;
 UBRR0L = 0x5F; //set baud rate lo
 UBRR0H = 0x00; //set baud rate hi
 UCSR0B = 0x98;
void init_devices()
 cli();
 uart0_init();
 sei();
 int main(void)
 unsigned char data;
 init_devices();
 data =1;
 while(1)
     data =0x21;
     UDR0 = data;
    _delay_ms(2000);
    data =0x55;
     UDR0 = data;
    _delay_ms(2000);
This is the code I used.
  • \$\begingroup\$ perhaps post your code as well? you could be communicating at the wrong baud rate \$\endgroup\$ Commented Dec 22, 2013 at 6:44
  • \$\begingroup\$ @geometrikal thanks for replying. i have attached the code too. \$\endgroup\$ Commented Dec 22, 2013 at 16:51
  • \$\begingroup\$ It seems you are not calling init_devices() from your main routine, so the UART is not getting setup. I found this on the web which could be useful www2.ee.ic.ac.uk/t.clarke/projects/Resources/zigbee/AVR/… ... it has example code for a serial port. Also, have you thought about burning the Arduino boot loader and then using the Arduino IDE / libraries etc? \$\endgroup\$ Commented Dec 22, 2013 at 22:12
  • \$\begingroup\$ I am going to try & run the program in another device today. I have written similar programs before and they have worked on other platforms. Can there be any fault with voltage levels or hardware configurations? \$\endgroup\$ Commented Dec 23, 2013 at 2:19
  • \$\begingroup\$ XBee requires 3.3V and UART level signals. P.S. did you try adding init_devices into main? \$\endgroup\$ Commented Dec 23, 2013 at 7:38
The problem was in the programming. Unless the fuse settings are changed the microcontroller uses its default 8MHz oscillator with a pre-scaler of 8. So effectively you should have a 1 MHz system frequency instead of 12 MHz. So for 9600 baud you have to put:
UBRR0L = 0x06; //set baud rate lo
instead of
This should take care of the problem. Though I do not know how to configure the fuses or whatever.
A few problems:
  • init_devices() must be called from inside main() otherwise it won't be run
  • data = 0; and data = 1; do not send out the characters '0' and '1' respectively. They send out NUL and SOH: see http://www.asciitable.com, and these characters will show as nothing in a terminal emulator. Instead, enclose the values in quotes, e.g. data = '0';, to send the characters '0' and '1' respectively.
  • Check the baud rate. With UCSR0A = 0x00; UBRR0 should be set to: (F_CPU / 8 / baud - 1) / 2; (source: Arduino serial library) where F_CPU is your CPU frequency in Hertz. With that in mind 005F seems like a funny value. Check the MCU frequency and calculate accordingly.
Some suggestions:
  • Funny characters on the serial output do suggest incorrect baud rate, however they do not always appear.
  • Download the Arduino IDE and have a look at / borrow their serial code.
So my guess is that there is something wrong with hardware setup
  • Don't preempt your trouble shooting but deciding on what the problem is ahead of time, or you might miss the real issue. I still make this mistake! :)
  • \$\begingroup\$ Thanks again will check again following your suggestions !! \$\endgroup\$ Commented Dec 24, 2013 at 0:00
  • \$\begingroup\$ Nice, please let us know if it doesn't work. I have a very similar setup running but with atmega328p. Also, to check baud rate you could connect the atmega168 to a PC? \$\endgroup\$ Commented Dec 24, 2013 at 0:15
  • \$\begingroup\$ @Geometrical .Thanks for all your replies. I have revised the program as you said (please check above ) and it was a very silly mistake to make. But still I am getting no output. I have a 12MHz crystal oscillator and I have my xbees configured for 9600 Baud rate. Now from the link below wormfood.net/… I have checked that with UBRR = 77 (ie 4D in hex ) I can get 9600 Baud with a 11.98 MHz crystal. Will that be ok or the slight mismatch is enough to throw my connection haywire? \$\endgroup\$ Commented Dec 30, 2013 at 7:25
  • \$\begingroup\$ I think that is ok, I forget the UART timing tolerances but less than 1% should be fine. Try connecting the 168 UART directly to the 2560 UART ( tx to rx, rx to tx, gnd to gnd ), bypassing the XBee completely and just check that. Do you have an oscilloscope? You could check the tx output with that as well. \$\endgroup\$ Commented Dec 30, 2013 at 11:45
  • \$\begingroup\$ Will do that thanks. Tried to simulate with Proteus but failed there too. Will try with a real oscilloscope in the new year !! \$\endgroup\$ Commented Dec 30, 2013 at 11:52
