6
I have seen a lot of projects that use a tape head, but there is very less information about how to build one yourself. Is this possible? I know that basically it is a metal core, with a coil around it and a very small gap. I guess the challenge in creating this at home would be to create that gap. Note that I am not looking for quality, it is just an experiment i would like to try.
  • \$\begingroup\$ Did you ever build one? If so, how well did it work? \$\endgroup\$
    – Russell McMahon
    Mar 13 '19 at 13:28
7
While Theran's answer is approximately correct, it's worth pointing out just what a "small" gap means.
For replay, the width of the gap should be no more than half a cycle of the highest frequency you want to replay, (and certainly less than a complete cycle!) For 20kHz, that means the distance the tape moves in 25 us. At 4.75cm/s (audio cassette) that distance is 4.75e-2 * 25e-6 m = 1.2 um. For a pro audio tape machine (38cm/s) 10um would be the maximum recommended gap.
For (audio) recording, it's a bit more complex; you want a wider gap to increase the magnetic field strength you communicate to the tape. Because of the AC bias, the actual gap width doesn't affect the frequency response so much, the recording takes place at the trailing edge of the gap : tape in the gap is being continually erased and re-recorded by the bias signal, so it's only the last half cycle that matters. You can get away with gaps of 3-4um (cassette) to 30um or so (15ips professional reel-reel tapes).
This is why all good audio tape decks have separate record and replay heads (though both may be built into the same casing). Off-tape monitoring is merely a bonus.
In short, although it may be theoretically possible, building a good one with even the best equipped home workshop would be difficult. And if you decide to go ahead, at least now you know what you are aiming for.
Also, while the gap may be 0.5 to 3mm long, if you are to play anybody else's tapes, that same tight micron tolerance must apply to straightness of the gap along its full length, and to its direction : it must be exactly at right angles to the tape (there is usually an "azimuth alignment" procedure to guarantee that). Otherwise high frequency response will be poorer than expected.
  • \$\begingroup\$ "Also, while the gap may be 0.5 to 3mm long", there are milimeters? I asked this because it seems a little bit too large. Also, can you tell how the gaps are realized in industry? \$\endgroup\$
    – Paul92
    Dec 26 '13 at 13:36
  • \$\begingroup\$ Yes - but remember this is the gap length, not width. Consider a 2-track (stereo) 1/4" (6.35mm) tape. Each track occupies about half the tape (minus a small gap) or 3mm, and the head must be aligned within a few microns across the full 3mm. I do not know how they are made. \$\endgroup\$ Dec 26 '13 at 14:47
  • \$\begingroup\$ +1 5+ years on :-) \$\endgroup\$
    – Russell McMahon
    Mar 13 '19 at 13:28
  1. Start with a ring of core material
  2. Cut a groove on the inside of the ring where the gap will be
  3. Wind the coil on the ring
  4. Fill the remaining space in the ring with epoxy
  5. Grind away until there is a small gap in the core
