I'm asking this because i'm trying to develop an active overvoltage protection circuit and unsure about how quickly it should react to overvoltage condition. Maybe someone can give me advice on that?
Thanks to everyone. I learned important things.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI'm asking this because i'm trying to develop an active overvoltage protection circuit and unsure about how quickly it should react to overvoltage condition. Maybe someone can give me advice on that?
An active over voltage protection scheme will be slower than such things as zeners. In any case you should ensure that any overvoltage condition is prohibited in rising to critical levels on what you are trying to protect more quickly than the protection device can respond. This can be achieved with passive components such as resistors, inductors and capacitors.
There can not be a general rule. Some components increase the current exponentially in case of over-voltage and some increase the current just proportionality.
In addition some may have over voltage mechanism (like a clamping diode) and some may not so there is not a single answer that can cover every single component/circuit.
It all depends on the mechanism of failure.
If the over-voltage damages the component by insulator breakdown, then no excess is allowed, no time is safe, pop! and it's dead.
If the over-voltage causes extra current to flow in a resistor, and heating is the problem, then you may get mS to minutes, depending on the thermal time constant of the circuit. If the supplier doesn't specify an \$I^2t\$ for the component, then it's down to you to do experiments, and make a suitable allowance for not all components being the same as the several you test.
