Recently i saw a video about Nest Protect, an smart smoke detector, that can be operated by waving your hand under it. Since there is no visible holes on the lower part i suppose they are not using any light/acoustic sensors, like IR or ultrasonic, so it could be an RF type sensor, but i have no idea what specific sensor, do you know how they detect the waving of the hand with such a precision?, i mean, i can easily detect movement with a PIR sensor, but i have no idea how to reduce the range (if possible) in order to detect only near objects movements.
EDIT: I found this picture of the sensor, they are actually two, one vertical and the other one inclined, seeing the picture can you tell what sensor type is?
