electrical engineering hopeful here.
Can someone explain with math how transmitting power at higher voltages reduces resistive loss?
I know Joule's Law
Power is proportional to (I^2)*R
lets say we have two identical direct current power lines - 1000 feet and resistance is 2 ohms.
One wire will run at 1,000 volts, and the other 10,000 volts. if both have a load of 500 watts, how can it be shown that the higher voltage line with experience less heating loss?
my botched attempt to solve this - I know half of every step i make is probably wrong:
wire 1: 1,000v load = 500w, so 500w/1000v = .5a = appliance amps 1000v/.5a = 2,000 ohms 2000 + 2 = 2002 ohm serial resistance. 1000v/2002r = .49a circuit amps (less current
wire 2: 10,000v load = 500w, so 500w/10,000v = .05 ohms = appliance 2 resistance. .05 + 2 = 2.05 ohm serial circuit resistance.
10,000/2.05 ohm = 4878a * 10,000v = 48,780,000 watts
    \$\begingroup\$ Your second calculation falls on its face immediately. \$\dfrac{W}{V}\neq \Omega\$ \$\endgroup\$
    – Matt Young
    Dec 29, 2013 at 3:48
  • \$\begingroup\$ thanks, yeah i realized that half way through. i sort of got so tangled in my own math mistakes and naivete I gave up and posted with obvious bone head mistakes. \$\endgroup\$ Dec 29, 2013 at 4:02
Wire 1:
V = 1000V
P = 500W
I = P/V = 500W / 1000V = 0.5A
R_wire = 2 Ohm
Loss in wire 1 = I^2*R = 0.5A^2 * 2 Ohm = 0.5W
Wire 2:
V = 10000V
P = 500W
I = P/V = 500W / 10000V = 0.05A
R_wire = 2 Ohm
Loss in wire 2 = I^2*R = 0.05A^2 * 2 Ohm = 0.005W
UPDATE:
To work out the exact loss, assuming voltage is measured at start of wire:
Total current, I = V1 / (R1 + R2)
Load power, P2 = 500W = I^2 * R2 = (V1^2 R2) / (R1 + R2)^2
This equation can be rearranged into a quadratic form and R2 solved for. Once R2 is found, the loss in the wire can be found by I^2 * R1
To find it using the P = VI formula, calculate V2 as I * R2, the loss is given by (V1 - V2) * I.
  • \$\begingroup\$ why does Joule's Law (I^2)*R give the same result as voltage * current? is V*I the exact same thing mathematically as I^2*R? thanks! \$\endgroup\$ Dec 30, 2013 at 7:30
  • \$\begingroup\$ Yes it will, but you have to use the voltage between the start and end of the wires, not to ground. The above calculation assume 1000v / 10000v is the voltage at the load end. I'll update... \$\endgroup\$ Dec 30, 2013 at 12:00
  • \$\begingroup\$ And P=I^2*R only applies to resistors, while V*I is always equal to power. \$\endgroup\$
    – Joe Hass
    Dec 30, 2013 at 18:19
