I'm using the Arduino Uno, CAN bus shield, and OBDII to DB9 Cable using their provided libraries. I was only able to initialize it.
Readings:
While connected to the car:
  • CAN-High: 2.7 V - 3.0 V
  • CAN-Low: 2.4 V - 2.7 V
While not connected to the car:
  • CAN-High: ~2.4 V
  • CAN-Low: ~2.5 V
Note: in both cases the Arduino is connected to my PC via USB (for debugging).
Sample code:
#include <SoftwareSerial.h>   //Software serial port
#include <Canbus.h>
#define CBRxD 5  // CAN BUS RX
#define CBTxD 4  // TX
#define DEBUG_ENABLED  1
char buffer[512];  //Data will be temporarily stored to this buffer before being written to the file
char tempbuf[15];
char lat_str[14];
char lon_str[14];
int LED2 = 7;
int LED3 = 8;
boolean scan = true;
SoftwareSerial canbusSerial(CBRxD, CBTxD);
void setup() {
    Serial.begin(9600);
    canbusSerial.begin(4800);
    pinMode(0, INPUT);
    pinMode(BTTxD, OUTPUT);
    pinMode(LED2, OUTPUT);
    pinMode(LED3, OUTPUT);
    digitalWrite(LED2, LOW);
    digitalWrite(LED3, LOW);
    setupCanbus();
void loop() {
    char recvChar;
    if (canbusSerial.available()) {  // Check if there's any data sent from the remote CAN bus shield
        recvChar = canbusSerial.read();
        Serial.print("CAN: "+recvChar);
    if (scan) {
        digitalWrite(LED3, HIGH);
        if(Canbus.ecu_req(ENGINE_RPM,buffer) == 1) {       /* Request for engine RPM */
            Serial.println(buffer);                        /* Display data on Serial Monitor */
        if(Canbus.ecu_req(VEHICLE_SPEED,buffer) == 1) {
        }Serial.println(buffer);
        if(Canbus.ecu_req(ENGINE_COOLANT_TEMP,buffer) == 1) {
            Serial.print(buffer);
        if(Canbus.ecu_req(THROTTLE,buffer) == 1) {
        //  Canbus.ecu_req(O2_VOLTAGE,buffer);
        delay(100);
void setupCanbus() {
    while (!Canbus.init(CANSPEED_250)) {
        Serial.println("CAN Init");
    Serial.println("CAN Init OK");
    delay(1000);
  • \$\begingroup\$ What output do you get on the serial terminal? \$\endgroup\$ Jan 1, 2014 at 3:05
  • \$\begingroup\$ Also, if you have a multimeter, switch it to ohms and measure the resistance across the CANH and CANL pins. Check out your pinout here. Should be pins 6 and 14. You may need to terminate the connection with a 120ohm resistor if it's not already terminated. \$\endgroup\$ Jan 1, 2014 at 3:08
  • \$\begingroup\$ first thing>> "CAN INIT OK". Then empty lines (printing empty buffer array) \$\endgroup\$
    – mabdrabo
    Jan 1, 2014 at 8:31
  • \$\begingroup\$ The resistance measured across CANH and CANL is 38.4 Kohm, and across CANL and CANH is 79.8 Kohm. (not sure if that's possible) \$\endgroup\$
    – mabdrabo
    Jan 1, 2014 at 8:36
  • \$\begingroup\$ yes, it checked it before it is 6 and 14, but how do i know it's terminated, if not how do i terminate it? \$\endgroup\$
    – mabdrabo
    Jan 1, 2014 at 8:37
I think your car is similiar to Opel Astra J. It uses GMLAN which is a low- speed CAN bus (33 kbit/s).
I've been able to read and send CAN data with the same hardware.
I had to connect CAN-H and CAN-L respectively to the SW-LS-CAN pin and to ground, according to the second table of page General Motors (GM) OBD II diagnostic interface pinout.
I used the code in https://github.com/Afterglow/arduino-gmlan.
Tell me if this works.
Their example code has
SoftwareSerial mySerial = SoftwareSerial(4, 5);
You have
Which translates to the opposite pin order
SoftwareSerial canbusSerial(5, 4);
Perhaps switching CBRxD and CBTxD would work.
  • \$\begingroup\$ i hope it works, i'll try as soon as i have access to the car. Should i be getting any different response on the serial monitor although not connected to the car? \$\endgroup\$
    – mabdrabo
    Jan 1, 2014 at 8:40
  • \$\begingroup\$ Unfortunately, it didn't fix it. \$\endgroup\$
    – mabdrabo
    Jan 2, 2014 at 9:45
  • \$\begingroup\$ Did the example code with the shield work? \$\endgroup\$ Jan 2, 2014 at 12:44
  • \$\begingroup\$ nothing has changed, i get CAN Init OK, and then all empty lines (empty buffer) \$\endgroup\$
    – mabdrabo
    Jan 2, 2014 at 17:42
  • \$\begingroup\$ Is the speed correct? In their code they init with CANSPEED_500 \$\endgroup\$ Jan 2, 2014 at 22:24
