I am looking to use a Texas Instruments MC33063 Buck/Boost regulator. I have never used a switching regulator before so this may be a conceptual issue.
My input voltage will probably be anywhere from 6 to 12V and I would like to use the regulator to buck down to 5V. However, I get confused when I read through the data sheet. Here's the layout for a step down from the sheet:
So the data sheet shows that if I were to input 25V, given this setup, I can get 5V. However what about 6 to 12V for a Vin?
Also, the optional filter is shown that \$V_{out} = 1.25(1 + R_2/R_1)\$. Is this independent of the input voltage? If so, what is the advantages of varying input voltages or is it simply flexibility?
Here's the link to the datasheet: http://www.ti.com/lit/ds/symlink/mc33063a.pdf
