Does anyone know any available reference to learn how works CORDIC algorithm to implement a division?
    \$\begingroup\$ I suppose you have already read the Wikipedia article? secure.wikimedia.org/wikipedia/en/wiki/Cordic \$\endgroup\$
    – starblue
    Jan 29, 2011 at 13:11
  • \$\begingroup\$ offcourse, but that article use trigonometric function to explain how it works. \$\endgroup\$
    – Peterstone
    Jan 29, 2011 at 13:32
  • \$\begingroup\$ This is more of a Stack Overflow kind of question \$\endgroup\$
    – Nayuki
    Jul 15, 2016 at 5:54
This is an excellent article written by someone on the Parallax forums, called CORDIC For Dummies. Well written and explains things nicely: http://forums.parallax.com/showthread.php?127241-CORDIC-for-dummies
  • \$\begingroup\$ I´ve just read and I agree with you, is an excellent and very clear article. \$\endgroup\$
    – Peterstone
    Feb 2, 2011 at 8:02
A CORDIC division is implemented using CORDIC multiplication, rearranging as follows: [source]
c = a/b
a - c*b = 0
For the multiplication z = x*y:
z is composed of shifted versions of y. The unknown value for z, may be found by driving x to zero 1 bit at a time. If the i th bit of x is nonzero, y i is right shifted by i bits and added to the current value of z. The i th bit is then removed from x by subtracting 2-i from x. If x is negative, the i th bit in the twos complement format would be removed by adding 2-i. In either case, when x has been driven to zero all bits have been examined and z contains the signed product of x and y correct to B bits.
This algorithm is similar to the standard shift and add multiplication algorithm except for two important features:
  1. Arithmetic right shifts are used instead of left shifts, allowing signed numbers to be used.
  2. Computing the product to B bits with the CORDIC algorithm is equivalent to rounding the result of the standard algorithm to the most significant B bits.
The division z = x/y is found...
... by driving x to zero using right-shifted versions of y. If the current residual is positive, the i th bit in z is set. Likewise, if the residual is negative the ith bit in z is cleared.
divide_4q(x,y){
   for (i=1; i=<B; i++){
      if (x > 0)
        if (y > 0)
           x = x - y*2^(-i);
           z = z + 2^(-i);
        else
           x = x + y*2^(-i);
           z = z - 2^(-i);
      else
         if (y > 0)
            x = x + y*2^(-i);
            z = z - 2^(-i);
         else
            x = x - y*2^(-i);
            z = z + 2^(-i);
   return(z)
You'll have to make a few modifications to use floating point numbers.
  • \$\begingroup\$ Since the Dr Dobb's website doesn't have all the detail, you can read the PDF at: siue.edu/~gengel/pdf/cordic.pdf \$\endgroup\$ Feb 24, 2015 at 6:53
    \$\begingroup\$ NOTE: if the bit about driving a X to zero (in Z = X*Y) sounded confusing: you are adding a multiple of Y to Z, for each set bit in X. Keep adding to the running total, until you run out of bits in X. \$\endgroup\$ Feb 24, 2015 at 7:00
