This is a follow-up question to https://electronics.stackexchange.com/a/95195/13354, in which I was asking about a specific solution to the more general problem described here.
I'd like to create a logic function that toggles with the (inverted) clock when enabled and stays low when disabled, like so:
clk ena out
0 0 0
1 0 0
0 1 1
1 1 0
In addition to that, I'd like the out
signal to be glitch-free, as shown in the following example waveform:
As shown in this image, potential glitches of the ena
input can happen shortly after the clk
edges; nevertheless, the out
waveform should be glitch free.
According to this answer to aforementioned question, the circuit should be a clock gate rather than a self-resetting flip-flop. This is the proposed schematic:
Unfortunately, this still causes glitches when ena
goes low, because the Q
output of the flip-flop is delayed with respect to clk
(note that I ignored the common delay between clk
and its inversion, which I think doesn't contribute to the issue):
Now my question: What circuit should I choose to have the out
signal glitch-free?
