I'm trying to program a PIC18F67J60 with a PicKit 2 but the device won't program.
The output from MPLABX PicKit 2 log is:
Found PICkit 2 - Operating System Version 2.32.0
Target power not detected - Powering from PICkit 2   3.25
2014-01-03 11:35:52
PIC18F67J60 found (rev = 0x3)
Erasing Target
Programming Program Memory (0x0 - 0x3f)
Programming Program Memory (0x1ff80 - 0x1fff7)
Verifying Program Memory (0x0 - 0x3f)
Verifying Program Memory (0x1ff80 - 0x1fff7)
Programming Configuration Memory
Verifying Configuration Memory
PK2Error0027:  Failed verify (Address = 0x1fff9 - Expected Value 0xf4 - Value Read 0x0)
The code is basically just blink an LED:
#include <xc.h>
#include <stdio.h>
#include <stdlib.h>
//general defines
#define _XTAL_FREQ 25000000
// CONFIG1L
#pragma config WDT = OFF        // Watchdog Timer Enable bit (WDT disabled (control is placed on SWDTEN bit))
#pragma config STVR = OFF       // Stack Overflow/Underflow Reset Enable bit (Reset on stack overflow/underflow disabled)
#pragma config XINST = OFF      // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG1H
#pragma config CP0 = OFF        // Code Protection bit (Program memory is not code-protected)
// CONFIG2L
#pragma config FOSC = HS        // Oscillator Selection bits (HS oscillator)
#pragma config FOSC2 = OFF      // Default/Reset System Clock Select bit (INTRC enabled as system clock when OSCCON<1:0> = 00)
#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor enabled)
#pragma config IESO = OFF       // Two-Speed Start-up (Internal/External Oscillator Switchover) Control bit (Two-Speed Start-up disabled)
// CONFIG2H
#pragma config WDTPS = 32768    // Watchdog Timer Postscaler Select bits (1:32768)
// CONFIG3L
// CONFIG3H
#pragma config ETHLED = OFF     // Ethernet LED Enable bit (RA0/RA1 function as I/O regardless of Ethernet module status)
int main(int argc, char** argv) {
  //OSCCONbits.SCS = 0b10;
  TRISB = 0x00;
  while(1){
    LATBbits.LATB0 = 1;
    for(unsigned char i = 0; i < 25; i++)
      __delay_ms(10);
    LATBbits.LATB0 = 0;
      __delay_ms(10);
  return (EXIT_SUCCESS);
Using PK2CMD I can see that the device is recognised with the auto detect however when I try to flash the HEX straight into the PIC I get this terminal output:
> pk2cmd -PPIC18F67J60 -M -F main.hex
PICkit 2 Program Report
3-1-2014, 11:34:51
Device Type: PIC18F67J60
Program Memory Errors
Address   Good     Bad
01FFFE    00FFFF   00F000
Which seems a different problem to the MPLABX output. Could this just be a bad chip (unlikely?) - any suggestions would be great.
UPDATE:
Schematic below:
Vcc is 3.3V so ENVREG is ties high to use the built in regulator to reg down to the 2.5V the chip actually uses, as a result the VDDCORE/VCAP is tied to ground with a 10uF electrolytic. X1 is 25MHz and I have tried the Pickit 2 MCLR straight into the pin, as it is here and also without the 0.1uF cap (as the datasheet suggests)
Circuit diagram
UPDATE 2:
I tried erasing the device with the following using PK2CMD
> ./pk2cmd -PPIC18F67J60 -E
Erasing Device...
Operation Succeeded
but sadly I still get the same error when trying to program - is there an alternative way to erase or is CP being set permanent on these chips?
UPDATE 3:
Interestingly if I unplug the PicKit 2 and run the circuit on external power only the LED is on - not pulsing, just on. Not sure if that is of interest but it's something.
And the device checksum in the project view in MPLAB for the device is Checksum: 0xC0C2
  • \$\begingroup\$ A schematic would be helpful. \$\endgroup\$ Commented Jan 3, 2014 at 14:29
  • \$\begingroup\$ Good point, added now \$\endgroup\$ Commented Jan 3, 2014 at 16:50
  • \$\begingroup\$ Is is possible it's a chip erase issue? You could try an "Erase Flash Device" procedure and see if that helps (I'm guessing that maybe the CP bits got set) \$\endgroup\$
    – carveone
    Commented Jan 3, 2014 at 18:00
  • \$\begingroup\$ @carveone Good idea but sadly no help - see my UPDATE 2 in the question \$\endgroup\$ Commented Jan 3, 2014 at 20:27
There are some ports called In Circuit Serial Programming that PICkit uses to feed the hex code into the microcontroller serially. When an external switch provides a voltage on these ports, this causes problems with the PICkit. You'll have to either disconnect these or put them in ground mode.
It's given in the PIC18F67J60 manual that:
The PGC and PGD pins are used for In-Circuit Serial Programming™ (ICSP™) and debugging purposes. It is recommended to keep the trace length between the ICSP connector and the ICSP pins on the device as short as possible. If the ICSP connector is expected to experience an ESD event, a series resistor is recommended, with the value in the range of a few tens of ohms, not to exceed 100Ω. Pull-up resistors, series diodes, and capacitors on the PGC and PGD pins are not recommended as they will interfere with the programmer/debugger communications to the device. If such discrete components are an application requirement, they should be removed from the circuit during programming and debugging.
Check them out and try grounding them or disconnecting them.
    \$\begingroup\$ Thanks - I don't have anything else connected to PGD or PGC (I always try to avoid using those pins for anything but ISCP for this reason) I will try adding in a series resistor though as I had forgotten that - any other thoughts? \$\endgroup\$ Commented Jan 3, 2014 at 13:19
The solution was to buy a PicKit 3 - all works fine now.
