I'm looking for a way to build a cheap 1m linear encoder. Precision should be around 2cm (which is not really "precision").
Any advice will be welcome.
@Joe Hass : yes it is moving. Not really fast. Speed is not a concern. 1m per 10s is ok.
Edit : Thanks for help, as asked I give more details. The device will pick paper in drawers arranged vertically. There's one moving paper picking device, and dozen of drawers on top of each others. I need accuracy to locate the drawers to pick from. And a good notion of speed and position for the PID system that control the picking device. I think two laser cut optical rulers will do the trick. (there's a fablab in my city).
    \$\begingroup\$ Gear track + rotary encoder \$\endgroup\$ Jan 5, 2014 at 21:23
  • \$\begingroup\$ What is it that's moving? How fast? \$\endgroup\$
    – Joe Hass
    Jan 5, 2014 at 21:25
    \$\begingroup\$ Absolute or relative? \$\endgroup\$
    – pjc50
    Jan 5, 2014 at 21:30
    \$\begingroup\$ Pulley on each end. String around pulleys and affixed to the slider. A linear pot on one pulley. Use to be very common. \$\endgroup\$ Jan 5, 2014 at 21:32
    \$\begingroup\$ Do you want to build 1 system cheap or produce hundreds of low-cost well engineered units? If it is one instance cheap and easy then, depending on many other aspects of the system, what about an optical mouse or making it out of parts from an optical mouse? \$\endgroup\$ Jan 5, 2014 at 23:43
5 Answers 5
6
I'm not sure of the mechanics of what you describe but if it slides on a specific legth bar you can use an optical sensor that reads either slots on the bar or reflective areas (like a shiny sticker every 2cm)
Another idea is the use of a small wheel that has a similar optical sensor and by reading the wheel movement you can calculate the distance.
  • \$\begingroup\$ With two reflective sensors an a 'staggered' pattern you have in effect a linear form of a rotary encoder. Add a limit switch and a micro-controller can easily maintain the current position. \$\endgroup\$ Jan 5, 2014 at 22:45
  • \$\begingroup\$ I take this one ! I will use two rules, one with short gaps to keep track of the speed? The other with spaced larger gaps to mark the drawers position. \$\endgroup\$
    – bokan
    Jan 6, 2014 at 2:29
  • \$\begingroup\$ Given the task is to arrive at a given thing (drawer) rather than an absolute measured distance/position, I would consider using a few such sensors to prove an indexed system where you always know you're in exactly the right place by the combination of light/dark on the sensors. That way the drawers can be differently sized, imperfectly spaced, etc. - as long as you have an indexed system that knows when it's at a given "stop" you don't have to make changes when something moves, goes out of calibration, etc. \$\endgroup\$
    – John U
    Jan 6, 2014 at 18:07
  • \$\begingroup\$ @JohnU : Yes that's what I meant. Fine graduation ruler to keep track of speed. And another ruler with gap for each stops. \$\endgroup\$
    – bokan
    Jan 6, 2014 at 20:11
  • \$\begingroup\$ @bokan - I was meaning something a little different. You don't necessarily need the fine one for speed unless you are moving quite fast/hard and require significant accel/decel time, but with the addition of a unique binary combination of light/dark patches/flags for each drawer you can arrive at exactly the right place. Using optos as binary input, 3 optos would give 8 combinations, 4 would give 16, etc. although you might want to reserve combinations for end-stops and probably "all zero" would be the "not arrived yet / no flag" state. \$\endgroup\$
    – John U
    Jan 7, 2014 at 8:55
There's half a dozen good ways of doing this. The choice depends on the mechanical design and the environment in which the sensor will be operation (as @wzab had mentioned above).
Here's one more variant for the pile. A spring-loaded spool of thin cord. The shaft of the spool is connected to a rotary encoder. The end of the cable is connected to the moving part, while the spool remains on the stationary part, or vice versa. The spring takes (or some other tensioning mechanism) the slack out of the cord. As the cord unspools, it turns the rotary encoder. An advantage of this method is that it can work with long travel. This method is widely used in the telescoping cranes to keep track of extension.
The suggested solution highly depends on the mechanical design of the system in which you are going to use it. E.g. if you are going to measure a distance between two objects, you may also consider using the ultrasonic transducer, e.g. something like: HC-SR04 (however its' applicability may depend on risk of interferences introduced by neighboring objects).
I would suggest a string potentiometer.
  • \$\begingroup\$ I wonder if you and I wrote about essentially the same type of sensor under different names? \$\endgroup\$ Jan 6, 2014 at 2:16
  • \$\begingroup\$ Oh, I'm sorry, I didn't notice. It's essentially the same mechanically, it's different electrically. Instead of requiring pulse counting or gray code decoding you just read a voltage divider. Quite similar overall, I agree. \$\endgroup\$ Jan 6, 2014 at 2:43
If you want cheap and easy then, depending on many other aspects of the system, you might use an optical mouse or might be able to make it out of parts from one.
