Anyone used one of the FT2232H chips from FTDI?
Specifically, how do you figure out the permissible baud rates?
The data sheet is kind of vague, and I have to pick something in the 1-3 MBaud range but need to know what my options are.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityAnyone used one of the FT2232H chips from FTDI?
I had this problem too. FTDI considers it more a driver issue than a chip issue. Head over to the FTDI App Notes area and look at the "AN_120 Aliasing VCP Baud Rates" PDF appnote.
Also noteworthy is that the Linux driver presently supports speeds (only?) up to 460800 baud.
Bxxxx
flags, but they can also do custom rates. Look at get_ftdi_divisor()
(line 1077) in the driver. You can set custom BPS rates up to 12,000,000 on the FT232H.
