In my A level physics I recently did an experiment to find what the optimum frequency to send a digital signal through a RG58/U Coaxial Cable is. My results are available on Dropbox. What I found was the noise ratio oscillated. There also appears to be a slight bell curve, with more noise in the middle frequencies than the outer frequencies.
I initially thought this may be due to standing waves, however my maths disproved this (might still be a valid theory though). We have some physicists in the Science department, but it'd be nice to hear some ideas from Electrical Engineers.
Any and all ideas welcome. It might be worth noting that I was conducting this experiment in KHz when coaxial cables usually work at much higher frequencies, does this make a difference?
What is causing the oscillation pattern?
  • \$\begingroup\$ Can you provide some more information about the physical setup of your measurement system? Something minor could be introducing noise \$\endgroup\$
    – AndrejaKo
    Jan 8, 2014 at 15:53
  • \$\begingroup\$ Here is a picture. I'm not sure if setup would make a huge difference, as I first measured noise without the cable and then noise with the cable, so any background noise would be cancelled out. \$\endgroup\$
    – SamW
    Jan 8, 2014 at 16:03
  • \$\begingroup\$ Not necessarily. I think that the cable itself might be picking up noise by itself. Is the signal generator shield end of the cable grounded? If it is, that might cause ground loops which might get picked up. One thing I would recommend for certain is to just connect the cable itself to the scope with the other side open and do a measurement. I'm not next to my scope at the moment, so I can't try it out, but I think that just connecting a BNC cable made measurable impact to level of noise. \$\endgroup\$
    – AndrejaKo
    Jan 8, 2014 at 16:11
  • \$\begingroup\$ By the way, that adapter at the scope side, it that just something like N to BNC? \$\endgroup\$
    – AndrejaKo
    Jan 8, 2014 at 16:26
    \$\begingroup\$ Your connection goes through two feed of non-coaxial cable. How can you expect all of it to behave "like coax", whatever that means? \$\endgroup\$
    – Phil Frost
    Jan 8, 2014 at 16:27
I did take a look at results of your research, but unfortunately, I don't have time at the moment to fully digest them, so I'll post a few I hope helpful notes about that you're doing.
First, for this demonstration, I'm using Owon SDS7102, which is a younger, more capable (1 gigasample per second, 100 MHz bandwidth) brother of he scope you're using.
First, a bit about the settings I'm using here: Under channel one settings, I've set the probe attenuation to be 1X since I'm not using a probe at all, meaning that there's no attenuation. Looking at your results, I thing that it would be very wise to check your probe settings and your signal generator settings, because the results look a bit unrealistic to me. Noise of 4 V is a bit too big even if the voltage of the signal is 86 V. Did you check the actual voltage levels with a multimeter? Could it be that your scope might be set in 10X mode when it should be in 1X mode?
Next, my bandwidth limit is off. Under acquire settings, I've set the acquire mode to peak detect. What this does is take a loom at all the samples of the ADC and show those which have greatest values. This is important if the sample rate is to be set below the highest sample rate, since it gives the most information about noise peaks. Record length is set to one megasample, meaning it will memorize 1 000 000 samples after each trigger. I don't think that your scope will have all this settings, but it may be a good idea to document them, just in case something strange is going on here.
As for the images here's a shot of its input without anything attached:
Oscilloscope screenshot, BNC connector empty
As you can see, peak to peak value of noise here is 2.4 mV.
Next, I'll just connect a 50 ohm BNC cable to the scope and post following picture:
Oscilloscope screenshot with BNC cable connected
Here we can see that the peak to peak value of noise increased more than 10 times by just connecting the cable with nothing attached at either end. Do note that some of the noise comes from signals getting reflected inside the cable itself.
In this next picture, I placed a 50 ohm terminator at the start of the cable and connected the cable with a BNC T-junction to the scope also using a 50 ohm terminator. The result of this is that any reflections off the cable ends should be absorbed by the terminators.
Oscilloscope shot of a 50 ohm BNC cable with 50 ohm terminators at both ends
As you can see, the peak to peak value of the noise here decreased to 8.6 mV. One more thing that needs to be taken into account is that the terminators physically close ends of the cable, so that the inner conductor is shielded inside of a Faraday cage, so it's a bit harder for stray signals to get into contact with the cable.
Next, there's the issue of grounding. One thing that can in some cases upset measurements and sometimes causes problems, especially in audio setups, are ground loops. I'm not sure if that's the case here, but it may be worth looking into in any case.
Unfortunately, the PDS manual doesn't have a handy grounding diagram, so I'll show diagram from SDS manual. Internally, both series work the same.
Here's the diagram: Oscilloscope ground connections diagram
What's basically shown here is that the ground connection on the power cord of the oscilloscope is connected to the ground clip of the probe. That connection goes through the outer conductor of the BNC receptacle. If the negative lead of the signal generator is also grounded, you might have current going through the BNC shield due to possibility of slight differences in ground potential. I've had this happen to me even with all devices directly connected to same power strip. Once again, I'm not sure if that's the case here or not.
Finally, a bit about Phil's comment. You're connecting a signal generator which is using a non-coaxial connector to a coaxial cable using an adapter. One of the problems here is characteristic impedance. The non-coaxial cable is going to have one characteristic impedance and then the coaxial cable is going to have another characteristic impedance. Then the scope itself will have input impedance of 1 megohm which is going to the much greater than the impedance of the cable itself and the signal generator as well. So what's going to happen here is that at each point the impedance changes, you're going to have signal reflections going back to the source of the signal. This can easily upset measurements.
Another problem which I can think of now is related to noise pickup in the non-coaxial part of the cable. Singe the signal conductor isn't shielded, it's going to pick up noise, but I think that you calibrated that out with the no-cable measurement.
There could be some other reasons as well, but this is all I can think of at the moment.
