I'm trying to mount an RF module that has 33 edge castellation pins. The data sheet says that the peak temperature is 250°C. I'm using 60/40 lead solder for a lower melting point but the solder will only melt at 315°C and I suspect that I'm burning the gates on these expensive modules.
Is reflow soldering the only way to mount components like these?
Alloys commonly used for electrical soldering are 60/40 Tin/lead (Sn/Pb) which melts at 370 °F or 188 °C
