Is the below a valid circuit implementation and are there any things to watch out for? It's a simplification of the larger circuit but the crux of it is that I need to sink current into two GPIO input pins. The pins are signified by the 1 and 0.
Also, would a diode on the pins be advisable?
Edit: Here's the non-simplified circuit. The question relates to the 3.3v part of it. In essence, the timer and decade counter sequentially pulse current, 'activating' the transistors one at a time. The keypad is a simple matrix keypad. What I'm wondering if I can do is to put a GPIO pin on the line between the keypad and ground. The intended effect is that, when a button on the keypad is pressed, 2 pins will change state - this signifies the row and column.
Note that some of the resistance and capacitance values are notional at the moment.
