My code:
#define MAX 10
const int LED1 = 2;
const int LED2 = 8;
const int LED3 = 4;
const int LED4 = 5;
int val;
int array[MAX];
int counter = 0;
int i;
int old_b = 0;
int error;
void setup() {
Serial.begin(9600);
pinMode(A5, INPUT_PULLUP);
int readButtons(int pin) {
int b,c;
c=analogRead(pin);
Serial.print("analogRead = ");
Serial.println(c);
delay(100);
if (c>1015) b = 0;
else if (c>70 && c<76) b = 1;
else if (c<128 && c>122) b = 2;
else if (c>169 && c<175) b = 3;
else if (c>209 && c<217) b = 4;
else if (c>247 && c<256) b = 5;
else if (c>280 && c<291) b = 6;
else b = 0;
if (b == old_b) {
return 0;
old_b = b;
} else {
return b;
stari_b = b;
void loop() {
while ((val = readButtons(5)) != 5) {
if (val == 1) {
array[counter] = 1;
counter++;
Serial.print("In ");
Serial.print(counter);
Serial.print(" saving ");
Serial.println("1");
delay(500);
} else if (val == 2) {
array[counter] = 2;
counter++;
Serial.println("2");
delay(500);
} else if (val == 3) {
array[counter] = 3;
counter++;
Serial.println("3");
delay(500);
} else if (val == 4) {
array[counter] = 4;
counter++;
Serial.println("4");
delay(500);
if (counter == MAX) {
counter = 0;
for (i = 0; i < MAX; i++) {
if (array[i] == 1) {
digitalWrite(LED3, HIGH);
digitalWrite(LED4, HIGH);
delay(1000);
digitalWrite(LED3, LOW);
digitalWrite(LED4, LOW);
delay(1000);
Serial.print("Executing ");
Serial.print(i);
Serial.print(" ");
Serial.println(array[i]);
delay(500);
if (array[i] == 2) {
digitalWrite(LED1, HIGH);
digitalWrite (LED2, HIGH);
delay(1000);
digitalWrite(LED1, LOW);
digitalWrite(LED2,LOW);
delay(1000);
Serial.print(i);
Serial.print(" ");
delay(500);
if (array[i] == 3) {
digitalWrite(LED2, HIGH);
delay(1000);
digitalWrite(LED2, LOW);
delay(1000);
Serial.print(i);
Serial.print(" ");
delay(500);
if (array[i] == 4) {
delay(1000);
Serial.print(i);
Serial.print(" ");
delay(500);
So I have buttons connected like this, except I have them 5. When one of the first four is pressed sketch stores 1,2,3 or 4 to denote which buttons was pressed and stores it in integer array. When the fifth (the "GO" button) button is pressed while loop ends and starts the for loop which according to the buttons pressed blinks LEDs. I want to make that while Arduino is blinking LEDs , that is while for loop is being executed, if at any time the fifth "GO" buttons is pressed it should stop blinking LEDs and start program from the beginning ( void loop { ... } ) that is again wait for the presses of first four buttons.
I managed to make this:
#define MAX 50
const int LED1 = 2;
const int LED2 = 3;
const int LED3 = 4;
const int LED4 = 5;
int array[MAX];
int old_b = 0;
int val;
int counter = 0;
int i;
int temp;
int L1;
int L2;
void setup () {
pinMode (A5, INPUT_PULLUP);
Serial.begin(9600);
int readButtons (int pin) {
int b, c;
c = analogRead(pin);
Serial.println(c);
delay(100);
if (c > 1015) b = 0;
else if (c > 70 && c < 76) b = 1;
else if (c > 122 && c < 128) b = 2;
else if (c > 169 && c < 175) b = 3;
else if (c > 209 && c < 217) b = 4;
else if (c > 247 && c < 256) b = 5;
else if (c > 280 && c < 291) b = 6;
else b = 0;
if (b == old_b) {
return 0;
old_b = b;
} else {
return b;
old_b = b;
void loop () {
if ((val == 1) || (val == 2) || (val == 3) || (val == 4)) {
array[counter] = val;
Serial.println(val);
delay(200);
counter++;
counter = 0;
temp = counter;
counter = 0;
for (i = 0; i < temp; i++) {
if (array[i] % 2 == 0) {
L1 = 2;
L2 = array[i] / 3 + 3;
} else {
L2 = 5;
L1 = array[i] % 3 + 3;
if (readButtons(5) != 5) {
digitalWrite (L1, HIGH);
digitalWrite (L2, HIGH);
delay(1000);
digitalWrite (L1, LOW);
digitalWrite (L2, LOW);
if (readButtons(5) == 5) {
i = temp;
} else {
i = temp;
So I still have a function which detects if a button was pressed. Prior to that, I have determined in which range are values for certain button. In the while () {...}
loop, while the 5th button isn't pressed, Arduino is "looking" if any of first four buttons was pressed. If it was store it in an array and if not keep "looking". When 5th button is pressed, we brake out and store last known place in array in which value was stored and set the place counter to zero so when starting again, Arduino stores values in the first place of array. Then based on that what is stored I determine which pin/LED will light up. If at any time during blinking LEDs 5th button is pressed again, Arduino stops the blinking and again waits for the presses from first four buttons. That is how it is supposed to work in theory. In practice I still can't get it to stop blinking every time 5th button is pressed again. I have to press it multiple times, sometimes two or sometimes even more times. I don't think using interrupts will help, since I don't know how I could use them in my problem.
loop
. How you do this depends on your microcontroller and the way in which it handles interrupts (stacks/unstacks). \$\endgroup\$ – nonsensickle Jan 9 '14 at 22:36
