6
I am debugging a power amplifier circuit and trying several capacitors values to fine tune the design to meet the frequency response specifications. All the 0603 and 0805 ceramic capacitors are experiencing the following issue:
I measure the capacitor (this one for example) using this digital LCR meter which reads 360nF (typical value 390nF with 10% tolerance). When I hand-solder the capacitor, it reads 420nF in-circuit, and when I desolder the cap, it still reads 420nF. What caused this big increase in capacitance?!
    \$\begingroup\$ That's nothing... Did you know that (especially smaller) ceramic capacitors change their effective capacitance based on their biasing voltage? an 0402 0.1uF capacitor rated at 50V isn't a 0.1uF capacitor if you only put 5V across it! \$\endgroup\$
    – akohlsmith
    Jan 11, 2014 at 20:14
  • \$\begingroup\$ Could the solder itself account for the capacitance change? When talking Nano, it probably would not take much. \$\endgroup\$
    – R Hughes
    Jan 12, 2014 at 7:26
  • \$\begingroup\$ @RHughes I don't think so. nF is pretty large. If it were nH that would be a different story. Parasitic capcaitances \$\endgroup\$
    – DKNguyen
    Sep 24, 2019 at 23:06
  • \$\begingroup\$ Does this answer your question? Why does the capacitance value of an MLCC (capacitor) increase after heating? \$\endgroup\$ Jul 21, 2022 at 18:43
The only clue I can find might be this: -
It looks like you are seeing a +16% shift in value and X5R is not known for the greatest dielectric so this may be counted as some form of initial aging due to soldering. After all, it started about 8% down and it's gone 8% over. I'd expect X7R dielectric to be better (stabler) and C0G/NP0 to be better again.
  • \$\begingroup\$ Caps have a maximum soldering temperature listed in their datasheet and usually a thermo profile for the reflow oven. This indeed has to do with changed capacitance after soldering. \$\endgroup\$
    – jippie
    Jan 12, 2014 at 9:59
Capacitor aging, including capacitance shift specifically after reflow is apparently an issue. See https://youtu.be/ZAbOHFYRFGg?t=675 (James Lewis, Kemet presented a talk at a Supplyframe Hardware talk: They're JUST Capacitors)
Change is regardless of whether power or temperature as long as you are away from curie point of the material.
The shift "resets" if the caps are reheated.
Check a few by measuring, soldering, desoldering and remeasuring.
Sometimes I put the component above a soldering iron , or in an instant freeze spray to get an idea of it's temperature coefficient.
You didn't say what the capacitor values were; if small, stray capacitance when soldered into the circuit could be a factor.
    \$\begingroup\$ The question already states "when I desolder the cap, it still reads 420nF", which means they are measuring, soldering, desoldering and measuring again. \$\endgroup\$ Jan 12, 2014 at 6:47
  • \$\begingroup\$ Think he meant check more than one cap in a solder/de-solder cycle to see if that one was just a fluke. \$\endgroup\$
    – R Hughes
    Jan 12, 2014 at 7:24
