I'm trying to come up with a solution to use the analog output of a DAC to drive the X-Y axis control of a commercially available laser 'closed-loop moving magnet' driver.
I found an explanation on how to use an op-amp to create a differential amplifier here and a calculator here, but I can't get that to work without a 2.5V reference voltage.
I also found a simpler design for such a circuit here, but when I try that in a simulator (I use iCircuit on my iPad) it doesn't swing from -10V to 10V but from -8V to 12V (approximately). This is the circuit:
This is my testing in iCircuit:
Tried it with the included circuit simulator, don't know how it works exactly:
My question is, is this simpler design the way to go, but are my resistor values wrong? Or do I need to go with the first circuit design but need to add something to get a 2.5V reference?
I have very little information on the exact electrical requirements of the scanner, but I'm assuming it's a product designed to be used in an ILDA laser device and fairly compatible to that standard.
UPDATE In iCircuit, I replaced the lower 10K resistor with 20K and the feedback resistor from 15K to 30K, and it looks like I'm getting the desired output now. Still, I don't know if this is trustworthy or not.
Bonus question: I have an ST LM324N opamp lying around from an old lab kit. Do you consider this device suitable for this task, if I supply +12V/-12V to it?
