I'm unable to get a proper response from my GSM modem300, sometimes it responds with nothing, sometimes it replies half of line of ONE message from full inbox, sometimes it just sends the command (AT+CMGR=1) I just sent, back many times.
Print screens:
I'm using Arduino, directly connecting the Tx and Rx of board to Rx and Tx of arduino, and GND to Arduino GND.
CODE:
char incomingByte=0;
void setup()
  Serial.begin(9600);
  delay(2000);
  Serial.println("AT+CMGF=1");
  delay(2000);
  Serial.println("AT+CMGR=1");
  delay(2000);
 void loop()
    while (Serial.available() > 0)
       incomingByte = Serial.read();
       if(incomingByte!='\n'){ Serial.print(incomingByte); }
       if(incomingByte=='\n'){ Serial.print(incomingByte); }
It might be worth mentioning that, I can send messages properly, and make and receive calls with no problem.
  • \$\begingroup\$ responds with half line of one message from FULL inbox!: imgur.com/zsmDcIc \$\endgroup\$
    – user280353
    Jan 14, 2014 at 10:17
  • \$\begingroup\$ responds with garbage: imgur.com/vTVSwyf \$\endgroup\$
    – user280353
    Jan 14, 2014 at 10:18
  • \$\begingroup\$ sorry to do this, -_-' site won't let me post more than 2 links. \$\endgroup\$
    – user280353
    Jan 14, 2014 at 10:19
  • \$\begingroup\$ Instead of posting links of images of GUI windows of text, could you cut & paste the text? Use small representative samples (not pagefulls) \$\endgroup\$ Jan 14, 2014 at 10:23
  • \$\begingroup\$ You are reading from serial in incomingByte and sending same byte on same serial! I am bit suspicious about this! And Not about problem, But You are doing same thing in if(incomingByte != '\n') and if(incomingByte == '\n') ... Why to write two conditions! \$\endgroup\$
    – Swanand
    Jan 14, 2014 at 10:24
See http://arduino.cc/en/Tutorial/SoftwareSerialExample
By using the same serial port to communicate with a modem and to communicate with your PC, you are causing confusion.
  • You are echoing the modem's reply back to the modem.
  • Modems usually echo commands back to you.
I'd use separate channels as shown in the Arduino serial tutorial.
Last time I did something like this (with an Arduino communicating with a MIDI serial device) I used a 16x2 LCD to display what was being received. But you could use software serial if you prefer (or don't have a character LCD)
  • \$\begingroup\$ Thanks GrittyBrick, I've tried software serial in a different way, now I'll try it again with the same code design and see what happens. If it works I'll let you know. \$\endgroup\$
    – user280353
    Jan 14, 2014 at 10:54
  • \$\begingroup\$ Still no luck, this is the reply: f~`8AT+CMGR=1 +CMGR: "REC READ","52266001",,"08/08/19,12:09:0 \$\endgroup\$
    – user280353
    Jan 14, 2014 at 11:36
  • \$\begingroup\$ no message body, not even other message headers \$\endgroup\$
    – user280353
    Jan 14, 2014 at 11:39
  • \$\begingroup\$ What happens if you replace the GSM modem with a wire link? Back in the day, we used to use a Peripheral And Processor Electronic Reactive Communications Link Interface Probe (P.A.P.E.R.C.L.I.P.) \$\endgroup\$ Jan 14, 2014 at 11:54
  • \$\begingroup\$ Getting the command replied back to me on hardware Serial, but on Software Serial I'm getting gibberish; diff baud rates too. \$\endgroup\$
    – user280353
    Jan 14, 2014 at 12:31
