6
According to user manual and several other official documents from Digi, xbee in the power down/sleep mode can consume as low as 1uA. But somehow such a low power consumption seems simply unachievable on my hands.
The following is my setup:
the DIN,DOUT,CTS,SLEEP_RQ,RESET,RSSI pins are connected to MCU, VCC connected to 3.3V source in tandem with a 10ohm resistor (for current consumption measurement), GND pin connected to ground. All other pins are configured as output as suggested by the manual.
The actual consumption measures at 0.7mA when SLEEP_RQ pin is asserted. Occasionally it can be as high as several mA.
I seem to be not the only person who can beat down sleep current into the realm of uA. The following is a blog post: http://www.socgadget.com/2011/07/low-power-xbee-module/
I am designing a battery powered sensor network. close to 1mA of power consumption in sleep mode is really a big burden on battery.
I'd like to gather some actual first hand experience. Also if anyone can give me some actual number of Z-wave power consumption in sleep mode would be great. Z-Wave also says in its manual that can be less than 1uA, but I'd like to know the actual number before invest several thousands into it.
Edit: Turning off UART TX line on MCU side seems not to make a difference.
Thanks in advance,
  • \$\begingroup\$ The modules should give very good low-power performance when using pin-sleep mode; it sounds to me as though you're not configuring it to actually go to sleep. I've observed on previous versions of the module that sometimes if a unit has been configured for an automatic sleep mode it won't honor a request for pin-sleep. Doing a "factory reset" and then requesting pin-sleep mode seems to fix that. \$\endgroup\$
    – supercat
    Commented Jan 14, 2014 at 16:29
  • \$\begingroup\$ This could be an issue. I'll check the module to see if they are in pure pin sleep or combination of pin & cyclic sleep. But to some extent, I am quite sure the module does go into sleep. Because the power consumption measures quite differently from up mode, a very brief of 20mA vs. long flat line at 0.7-0.8mA level. \$\endgroup\$
    – Zhiyong Li
    Commented Jan 14, 2014 at 17:09
  • \$\begingroup\$ The 20mA represents time the radio is on. The 0.7mA probably represents current required for the module to stay awake well enough to respond to serial data. I don't think the version I used had an option to sleep the radio receiver but allow communications with the host CPU, but some other ones might. \$\endgroup\$
    – supercat
    Commented Jan 14, 2014 at 17:13
  • \$\begingroup\$ That may actually explain what is happening. Some current to keep UART alive on the xbee side. But I don't intend to communicate with xbee after I assert sleep_rq pin, because at the same time MCU is also put into sleep. I will try to do something on the MCU side to make DIN & DOUT don't look like UART interface. Hopefully this will make a difference. \$\endgroup\$
    – Zhiyong Li
    Commented Jan 14, 2014 at 17:31
  • \$\begingroup\$ It's possible that the XBEE uses the existence of a high level on its RX pin (your DOUT) as a signal that the processor should stay alive enough to communicate, though the ones I've used before didn't do that. I would expect that there would be an option to control such behavior (for use with devices that can't force their serial output to ground). \$\endgroup\$
    – supercat
    Commented Jan 14, 2014 at 17:37
First, to answer your question:
The actual sleep current of the Xbee Series 2 modules is dependent on voltage and temperature. Over the entire voltage range, it is less than 10µA. At the typical voltage, and 25°C, it is less than 1µA. Product-to-product variation makes it useless to specify the current any more precisely, because it will be different for each module. But it will definitely be under 1µA.
In other words, the actual sleep current is... well... what they say the actual sleep current is.
The thing to keep in mind is that this is not the sleep current you will get simply by entering power down mode. This is the lowest current it is possible to get in power down mode. Put another way, that doesn't imply that simply powering down the device will yield this current. It means if a bunch of other stuff is arranged just so, a bunch of conditions met, and all sorts of other little gotchyas taken care of, with not one single thing overlooked, you can get <1µA current draw in power down mode. Power down isn't a magical on/off switch (as much as we wish it was), it usually just shuts down the CPU core. You have to manually shut off other things before that, all the things that isn't effected by the SM = 1 condition and only when all of that is taken care of, do you then power down the core.
With that in mind, I'm going to go over some pitfalls that any one of, or some combination of, would yield such high sleep currents. In fact, it is especially important to avoid 'silver bullet' thinking in these situations. That's where you assume that there is a single mechanism behind the problem, and thus the problem has a single, 'silver bullet' solution. In reality, it is probably several different things working in combination.
  1. GPIOh no
    The Xbee Series 2 (and newer cousins 2B and 2C) modules IO pins operate independently of the CPU core. Pin sleep, simply put, doesn't actually effect the IO pins. The CPU core can change and configure them, but that's all. So those pins will simply continue doing whatever it was they were doing (being inputs, or driven how you last set them as outputs, etc.) regardless of if you're powered down the module or not. Pin sleep will not take care of anything GPIO related for you, you have to do that yourself.
    You mention setting all unused pins to output... but with what state? You must set unused pins to output, default low to achieve the lowest sleep current. So double check that.
    Also, turn off the pull-up resistors on all those unused GPIO pins, even though you're setting them as outputs, not inputs.
    Once you've made extra sure you're doing the above, then we can move.
  2. The battery always loses in a pin fight.
    If you didn't have your outputs set low (even though they're unconnected), that could have contributed to some of the current draw. But I suspect you'll also find something not quite right with the only other thing we can examine: the connected pins. In other words, the lines running from the Xbee to your MCU.
    You do not want to double up on pull-up/pull-down resistors. For every line between the Xbee and the MCU, make sure you've disabled the MCU's internal pull-up resistors. Regardless of their direction (input/output). Let the Xbee's pull-ups, and only those, do the work.
    Also, make sure your MCU is behaving correctly in terms of what it is actually doing to those lines it has connected to the Xbee. Turning off the UART TX line is not behaving correctly. (Though, it didn't make things worse, obviously). Don't over think this: it's a UART port with CTS flow control. So do what you're supposed to do, and simply treat it like any other UART port with CTS flow control: respect the CTS, that's all. Don't forget the MCU's internal pull-ups, those should be turned off. Now, we want to make sure the pins are set at the right levels. The MCU's TX pin, when inactive, should be high, and since a sleeping Xbee asserts CTS high (meaning, 'don't talk to me!'), that means the MCU's TX pin should be set to high. Putting it in any sort of high Z state is not correct, don't disconnect it or whatever you're doing.
    The MCU RX line will be driven high by the Xbee, so make sure the MCU's pull-up on this input is disabled. We don't need it, since it's being driven. And there will be leakage, as nothing is ever quite at the same potential, if there is that extra pull-up path.
    Make sure your RSSI pin is being set to output low before sleep, and make sure your MCU has it's pin on the other end set to input low/no pull-up. If there is a pull up active, you'll be pulling to down and seeing extra sleep current draw.
    Make sure any Xbee pins that are inputs are not being driven low by the MCU for some reason (and verify the behavior since you're putting the MCU to sleep as well. Make sure it isn't pulling something low unexpectedly. Silicon errata is a real thing).
And, finally...
  1. Mo measurement, mo problems Sometimes, you might just be measuring wrong. How confident are you in the accuracy of the meter you're using? You're measuring via the voltage drop across a 10Ω resistor. Even in power-down mode, the Xbee will wake up to reset a few timers and what not every few seconds. There can be very short current spikes, and a 10Ω resistor might be dropping the voltage enough to trigger brownout circuitry or do other weird stuff. It would be a good idea to add a really nice and fat tantalum capacitor, at least 100µF, across the Xbee module's power inputs, but after the 10Ω sense resistor, to decouple the power more from the 10Ω resistor. This will also serve to filter out any current spikes, which can often cause erroneous readings on multimeters, since they expect steady DC. Again, this likely isn't the sole cause of your high sleep current (or at least, high sleep current reading), but it might also be contributing.
All of the above applies just as much to the more recent 2B or 2C series Xbees, so don't let the age of this question (almost 4 years old now!) fool you, my answer still applies even in 2018. I fear it might be too late to be much use to the question author, but I hope not.
  • \$\begingroup\$ Thanks for typing such a long answer. It would be nice if you can include some first hand actual numbers on power consumption. \$\endgroup\$
    – Zhiyong Li
    Commented Dec 31, 2017 at 23:16
