I have just opened up a small, low-cost motion-activated (by PIR) LED light as I am planning on just using the casing for another project.
The PCB inside is clearly designed to be very cheap. It uses a BIS0001 PIR IC found in many other PIR products. There is heavy flux residue, the PCB is thin, and there are bodge capacitors straddling the IC. It's cheap.
For this reason, I am surprised that there are 4 ferrite beads on small wire jumpers, as shown in this image. The wires are the battery connections and the SPDT mode switch.
PCB macro
This is fairly common on mains powered equipment, switch-mode power supplies, networked equipment and anything involving high frequencies.
The device is battery powered with no option for mains power and is totally standalone.
The pyroelectic sensor and phototransistor are mounted on a separate PCB. These are connected by hookup wire that is twisted, potentially indicating there are other noise issues on the board.
But why are there 4 of them on this dirt-cheap PIR?
  • \$\begingroup\$ Specifically, what are those wires used for - the ones that go to the circuit board which have the F-beads? Are they AC power input or connections to other parts of a system the sensor might be used in? \$\endgroup\$
    Commented Jan 19, 2014 at 13:06
  • \$\begingroup\$ Added some clarification. \$\endgroup\$ Commented Jan 19, 2014 at 13:57
  • \$\begingroup\$ Another probability, the board was originally from a run for a Mains powered PIR device, or from a recalled product line scrapped for parts to save face. \$\endgroup\$
    – Passerby
    Commented Jan 19, 2014 at 19:59
8
Two possibilities - either or neither may be correct :-).
  • They wish to meet emission standards to some extent for unknown reasons. They may have found that the device caused problems for other equipment it was used with.
  • More likely - just the opposite. You note that the design and construction suggest a very low construction cost product. They may have cut corners in areas that they have little or no understanding of. A PIR detector can be quite a sensitive device. They may have experienced marginal operation and noise problems and found that eliminating noise via the external connections improved operation reliability.
Larger version of your photo here
The added-afterwards power supply decoupling electrolytic (probably) suggests desperation, and the added to its leads after-afterwards 0.01 uF suggests that desperation was not enough to make it work well enough. That is hardly a level of production level assembly that you'd expect.
Other:
The 4 8's at top middle do not seem to have been auspicious enough to remedy the problems.
The hot-melt glue at left will fall off within a year and probably less.Regardless, it is not doing much of a job of providing strain relief. The blue wire looks to be in mortal peril if external movement can move it, and others are not much better.
Added:
The caps across the IC are between VCC and the sense input from the sensor. I'm not 100% sure of function, they aren't there on normal BIS0001 boards.
That adds weight (but not certainty) to the theory of noise input being a problem. If they were sensor to ground it would be more likely, but unless the Vcc line is noisy and they are providing feedback (!) then they should reduce noise (and signal) variations at the input. The beads would help keep noise out of the system overall. They do however seem to be part of the original design, although how they are connected electrically is not certain from the photo.
  • \$\begingroup\$ I wonder what happened... They must have made heaps before noticing a problem, otherwise soldering those extra caps on would not be worth the labour cost? \$\endgroup\$ Commented Jan 19, 2014 at 14:01
  • \$\begingroup\$ The caps across the IC are between VCC and the sense input from the sensor. I'm not 100% sure of function, they aren't there on normal BIS0001 boards. \$\endgroup\$ Commented Jan 19, 2014 at 14:07
  • \$\begingroup\$ "The 4 8's at top middle" do you mean the ferrite beads? Where does the 8 come from? \$\endgroup\$
    – jippie
    Commented Jan 19, 2014 at 17:40
  • \$\begingroup\$ Yes, the blue wire fell off immediately after taking this picture. The hot glue hasn't adhered at all. I'm just using it as a wireless occupancy sensor - the case is well made, has the right batteries, and a PIR window. \$\endgroup\$ Commented Jan 19, 2014 at 20:32
  • \$\begingroup\$ @jippie - 8's -> weak joke. Especially on the large version photo a board number is visible at top middle of photo. Maybe CH8888. I assumed that the 8's are intended to be auspicious, but maybe not. \$\endgroup\$
    – Russell McMahon
    Commented Jan 19, 2014 at 22:43
Don't assume everything out there was designed by someone that really knew what they were doing, or that engineering decisions dominated.
Your photo gives the impression of some intern being told to "fix" the problem, whatever that may have been. The owner was probably a sales and accounting guy, so all engineers look alike, so a intern is better than some old fart that wants to be paid real money. Then we can blow off the engineering "department" (the intern) as soon as he has comes up with a fix. We'll never need another engineer after that. Or, maybe this was the second intern fixing the problem from the last one after the first one got canned because the design was done and engineering wasn't needed anymore. By the time the second intern was brought on, those skematic thingies the first one was supposed to write couldn't be found.
No, this sort of stuff really happens.
  • \$\begingroup\$ Never attribute to malice what you can attribute to stupidity I guess... \$\endgroup\$ Commented Jan 19, 2014 at 17:57
