Okay, here is a block diagram of a typical microcontroller (PIC16F616) I/O pin (Figure 4-1 in datasheet).
Manufacturers do not typically publish transistor-level descriptions of anything complex these days, but we can deconstruct the block diagram with a bit of effort.
If you want transistor-level schematics of a D flip-flop, it would be something like this (taken from a 74HC74 datasheet):
Where the T.G. blocks are transmission gates, similar to CD4016.
Inverters and gates, you can look up transistor-level schematics in 4000-series CMOS data sheets such as the 4002 4-input NOR.
Of course on a microcontroller chip there would not be ESD protection networks on internal
nodes, so that part of the schematic would not be present.
This is all pretty standard CMOS logic. There are two things that are a bit unusual. One is the P-channel transistor marked "Weak" in the GPIO pin block diagram. It is a "Weak" transistor (it has small physical geometry so Idss is only microamperes when it turns on). It is there to act as a pullup current source (similar to a pullup resistor). As you can see, it's only on when selected (/RAPU global weak pullup enable is true), the input is not in analog mode, the pin is tristated (on a PIC this means that the pin is an input, so we don't waste pullup current into an output), and WPUA (individual port pin weak pullup enable is true).
The diodes shown are a simplified representation of the GPIO pin protection network.
The other critical thing is the non-inverting buffer driving the I/O pin. It is a tristate buffer. When the pin is selected to be an input (TRISA is true), the buffer output is driven high impedance. The schematic will be something like this part of a MC14503 (minus the input inverter, since the input is an ENABLE input not a DISABLE input.
When the ENABLE input is low, both transistor are off, and the pin is no longer driven as an output (on a PIC this occurs when TRISx .. where x is the port number.. is true (HIGH)). A normal inverter has either the "top" (p-channel) or the "bottom" (n-channel) output transistor on at any given time. The tristate buffer has a third state with both transistors off. The fourth possible state (both transistors on, across the power supply) is generally not considered very desirable, and the shown arrangement of gates prevents it from occurring.
That is the only part that gets switched when the pin is selected to be an input or output (see the TRISA output from the latch flip-flop on the top schematic- it only goes to the output buffer enable) . There is no reason to switch the inputs off- they remain connected to the output at all times- since they present negligible load. Similarly, the analog peripherals (if any) are designed so they do not present any load.
