I was wondering if I could know the transmission speed between 2 PICAXEs using an Radio Module.
At the moment I tried to send data between 2 PICAXE 40x2 only with the 433MHz Radio Transmitter. The transmission works but its speed is very slow, like 1 package every 5 seconds.
Is it possible to increase this transmission speed?
I also read I should use the NKM2401 Radio Encoder/Decoder.
I'm pretty sure you are asking about transmission rates not transition rates.
The transmission speed depends on a variety of factors including (but not limited to)
  • the type of interface between PICAXE and module
    • it's clock rate or baud rate etc
  • the radio signalling system used by the radio module
  • the data encapsulation and protocols used by the module or Picaxe
  • the amount of local interference/noise in the radio spectrum used
    • assuming checksums and retransmits are used.
| improve this answer | |
  • \$\begingroup\$ Ups, you're right. Sorry. \$\endgroup\$ – GerardMT Jan 20 '14 at 18:47
  • \$\begingroup\$ Ok, thanks. Now I have more idea of what might be wrong. \$\endgroup\$ – GerardMT Jan 20 '14 at 18:49
