I have a Jaguar motor controller that has a set of 5 inset male header pins to connect an encoder. The encoder has only loose wires coming out.
What type of connector should I be buying to solder/crimp onto the end of these?
Also, there're a couple of sensor boards with a similar arrangement of 0.1" male headers. The control board also has male headers. However, every compatible cable I can find is male to female.
Do servo cables with sockets at both ends exist?
This is what the controller looks like. Encoder slot is on the front, as the freehand-circling below shows
