Question
What are the steps required to join the microphone and audio lines from a typical cell phone headset into one line so that the audio can be recorded by a standard voice recorder using the microphone and/or line-in input?
Practical use
The practical use for this is for the purpose of recording cell phone conversations with the use of a headset.
In Depth
Intuitively, I would just splice all the lines together. However, this approach seems to have the problem of creating an echo from the mic line to the audio line. I've also heard that it could blow some circuits in the phone, audio recorder or both.
It seems that the job of "splicing: these lines together without interfering with the call is more complex, requiring the use of some components to make it work correctly.
Here is a device that I found on Ebay that does exactly this: enter image description here
I purchased a similar device off Ebay that has its own headset attached and cracked it open: enter image description here
Here is a close up of the cracked open part. It does not look very complex, but I'm not sure exactly what it is doing: enter image description here
(Other side:)
  • \$\begingroup\$ There may be more on the other side of the board. At a guess it's a single transistor (Q1 in the centre) preamp with some filters around it. \$\endgroup\$
    – pjc50
    Jan 22, 2014 at 0:42
  • \$\begingroup\$ @pic50 - Thanks for your response! I just checked the other side of the board. There are no components there. \$\endgroup\$ Jan 22, 2014 at 0:53
  • \$\begingroup\$ Did you look for an app to run on the phone to record directly into phone memory? \$\endgroup\$
    – Transistor
    Nov 8, 2015 at 9:33
  • \$\begingroup\$ I really need to find the device that you refer to above that you found on ebay.... can you provide a link or at least some good search keywords to find it please? \$\endgroup\$ Apr 3, 2018 at 1:07
In this context "audio line" means a signal level & output impedance intended to drive a typical pair of earphones. I'll assume mono rather than stereo.
I'd guess the processing steps may be not entirely unlike the following:
  1. for mic-in (could be entirely passive?)
    1. Attenuate the headphone signal to mic levels
    2. mix audio signals
    3. buffer output
  2. for line-in (choose either pro or consumer level)
    1. amplify the microphone signal to line-level.
    2. amplify or attenuate earphone signal to line-level
    3. mix audio signals
    4. buffer output
By buffer output I mean set the appropriate output impedance.
For stereo, you'd typically split the mic signal and mix equally into left and right channels.
For recording conversations you might want separate automatic gain control (AGC) for each side of the conversation. Since conversations are mostly half-duplex I guess you mostly only need one AGC element.
