The scanner would be scanning for 15 minutes each hour, and the raspberry pi would be always on or could be turned off between scans. What specs would I be looking for in a solar array?
Canoscan max power consumption: 15W
    \$\begingroup\$ Realistic? That's subjective. Buy a big enough panel and battery, anything is realistic. 15W for 15 minutes is like 4 W for an Hour, plus 5 W for the RPI, you only need ~10W of power. Fairly small load, reasonable. \$\endgroup\$ – Passerby Jan 23 '14 at 3:33
  • \$\begingroup\$ Thanks. Could you suggest a panel and accompanying battery that could reasonably accommodate this load running 24/7? \$\endgroup\$ – enigmaticeasteregg Jan 23 '14 at 3:57
  • \$\begingroup\$ So;lar insolation hours/day by month at www.gaisma.com. Work out total Watt-hours load per day. Provision panel to provide 2 x to 3x that at minimum sunshine hours/day at your site. | Battery capacit in Wh needs to provide at least 1 days work BUT deep discharged batteries die so dimension to part discharge battery. If you want N days weather backup you need N x as much battery capacity. \$\endgroup\$ – Russell McMahon Jan 23 '14 at 7:25
The battery sizing will be dependent on a couple of things:
1) how much sun will this location get? Without that info you can't determine what your long-term average recharge (i.e. power input rate) is.
2) what your risk tolerance is. If you're going to "properly" engineer this beast, you'll need to figure out what you expect your worst case solar power is. Said another way: "What's the longest period of time that you expect little to no solar input?" If you're in a location (like I am) where you might well get 4 days of thick overcast in a row in the middle of december, that's a very different calculation than if you're in a mostly sunny climate near the equator. There are insolation charts for the USA here (and lots of other places): http://www.gogreenenergyusa.net/images/insolation-map.png
Some of this will be educated guessing: if you want to be able to go a week without a sunny day, you'll need a battery that can provide (10W * 24hr * 7 days --> 1680Whr). Note most batteries are actually specified in Amp/hours at a given discharge rate, and since you will likely be cycling yours quite a bit you probably don't want to deeply discharge the battery all that often because that shortens the effective life.
in short, you have more questions at the moment than you do answers. ;-)
| improve this answer | |
I'd go for the most practical/cheap approach:
Use the cheapest car battery with a dashboard solar pannel battery-charger.
But I have no idea if you can supply your Canoscan with only 12V...
(If you prefer better looks... look for PowerGorilla on the net, it's a backup battery for laptops and they also supply solar chargers. You can select upto 24V output.)
Good Luck!
