There is an eval board for the Xilinx Zynq-7000 FPGA called the Zedboard. When you look at the board you will notice a very interesting pattern of bypass capacitors. The designer has a technical note that explains why he/she thinks this is a good way to do bypass for a board like this.
Are there any flaws in the reasoning behind this bypass capacitor scheme?
Zedboard bypass cap locations around FPGA
Disclaimer: I will not answer my own question, as I really would like other experts from this community to bring their knowledge to the table. But I may do a measurement some day to find more facts - and may blog about it + add that here.
  • \$\begingroup\$ In that PDF, the author describes how trace and via inductance can be an issue. The author then talks about how he measured the power supply ripple, directly across the capacitor pins, therefore completely failing to measure the ripple value that matters at all (the one at the pins of the Zynq, after the via and plane inductance). What? A proper way to test the decoupling would be to add test-pads on the bottom side of the PCB that expose the power delivery vias, and even that isn't ideal. \$\endgroup\$ – Connor Wolf Jan 23 '14 at 9:12
  • \$\begingroup\$ Basically, that's a giant pdf with the conclusion "Capacitors work!". \$\endgroup\$ – Connor Wolf Jan 23 '14 at 9:14
He seems to be trying very hard to justify his design tradeoffs. @Conner Wolf is completely right, measurement across the capacitors is not (all) we care about. Trace/via impedance at the current ripple frequencies you see on power-pins on these high-clock-speed parts can become really considerable.
Its all a little unusual, every design has tradeoffs that need to be made and you try to chose wisely...and then verify under test of course. You don't need to write a PDF about why you needed to put x in position y because of limiting factor z.
BGA is generally a pain to route-out but I usually try to place/route clock sources first and then decoupling/power and THEN signals. My logic is that I've had issues with clocks before, but no issues yet with decoupling or signals and that I would consider optimising decoupling and power routing to be higher priority than signal routing.
