I built this circuit and simulated it in CircuitLab and was trying to make an active low pass filter. However, it shows a frequency response like a resonant low pass filter and I can't figure out why.
Here's the schematic:
And the frequency response:
The gain of the frequencies below the resonant frequency is set by the ratio of R2/R1 (x10 with these values), as expected for an inverting op-amp circuit. But I can't figure out why there is the resonant peak at 800 Hz for this first-order circuit, or how to calculate the resonant frequency.
And the response of a few different cap values:
And the response of different values of R1:
Changing the value of R1 has no effect on the resonant frequency, only on the gain of the circuit. I don't understand why this circuit behaves this way. Can anyone explain it to me?
I came up with this equation for the value of \$V_{out}\$:
$$V_{out} = -( \frac{A \times R2}{R1 + R2 + R1R2Cs - A \times R1} ) V_{in} $$
Does this equation look right? It makes sense to me that when \$(R1 + R2 + R1R2Cs) << A \times R1 ,\$ the result is approximately equal to R2 / R1. But I have no idea where the peak at 800 Hz comes from.
