We are supposed to find \$i_o\$. Looking at the 25-V voltage source and the \$5k\Omega\$ resistor, the current is \$i_x=\frac{25}{5\times10^{-3}}=5mA\$ because the voltage across both inputs of the op-amp are equal (ideal) and zero because the positive terminal is connected to the ground. Using node votlage equations at node \$V_1\$ and \$V_0\$, $$\frac{0-v_1}{50\times10^{3}} +\frac{0-v_1}{10\times10^{3}} = \frac{v_1-v_0}{40\times10^{3}}$$
Knowing \$i_x\$ allows us to determine \$V_1\$ which is \$50\times10^{3} \times 5\times10^{-3}=250V\$ Is it \$-250\$V?
Solving for \$v_0\$ I got \$-550V\$. Using KCL at node \$v_0\$, \$i_0=i_1+i_2=23/600 A\$
But, for some reason, the answer is wrong. Am I missing something? Did I do something wrong somewhere?
