I have purchased a nice light bulb with long visible wires/resistors and plugged it in, on the ceiling. It burns too bright without a dimmer and does not look as intended (also the lifespan decreases).
I would like to permanently dim it. However the light switch does not have enough space inside it for a full dimmer, though I can fit something smaller. I was thinking of connecting a big resistor serially to the bulb.
Is that a good idea? I was thinking around 2 KOhm, as I figured that is the typical lightbulb resistance and therefore it would halve current. What is the difference with the 0.1W and the 50W ones? Can either take the 220V we have over here? Would it overheat closed inside the switch hole? Am I talking nonsense and should I go back to reading my uni books again?
  • \$\begingroup\$ What is the bulb specs (wattage, voltage)? Can you just replace it with a lower wattage bulb? \$\endgroup\$
    – JYelton
    Jan 31, 2014 at 0:10
  • \$\begingroup\$ It doesn't mention specs on the bulb. And replacing it is not an option. I don't think they do lower wattage, the box/manual mentioned that it should be dimmed. \$\endgroup\$
    – Dimitris
    Jan 31, 2014 at 0:20
    \$\begingroup\$ Whether or not a resistor would work, if you have to ask this question, playing with mains voltage is probably not a good idea, unless you want to start a fire and be denied your insurance claim. \$\endgroup\$
    – Phil Frost
    Jan 31, 2014 at 0:25
    \$\begingroup\$ Would adding a resistor within the back-box of a light switch comply with Part P of the building regulations? \$\endgroup\$ Jan 31, 2014 at 10:18
  • \$\begingroup\$ To be honest, I have no idea about regulations. Do you have any other suggestions that would comply with any regulations? \$\endgroup\$
    – Dimitris
    Feb 1, 2014 at 13:30
8
I am going to assume it's an incandescent bulb of the "artistic" type with interesting filament structure. If it's an LED or CFL bulb, the below comments do not apply.
It's possible to connect a silicon diode in series with the bulb to permanently dim it. The behavior is not linear because the light bulb proportionally sucks more juice (technically speaking) when the tungsten filament is not running at full temperature. There's no way to adjust the brightness, so it's either acceptable to you or not.
The diode part number would be different depending on the bulb wattage, but a 1N4007 should work for anything up to 100W or so, and a 1N5407 for about any bulb you'd be likely to use. Be prepared to occasionally replace the diode after the bulb blows- the symptom would probably be the new bulb operating at full brightness. There's less chance of that happening with the 1N5407. They're less than 50 cents each.
If you have a bunch of them, you could install them in random orientation (which end of the diode goes to which side of the power) to be nice to the power company.
Note: I have no opinion on whether this is acceptable to fire, insurance or other codes and regulations in whatever 240V country you're in. Electronically it will work.
  • \$\begingroup\$ Do you think the flicker would be noticeable, or is the thermal mass of the filament sufficient to reduce the luminosity ripple to something that won't require an epileptic seizure warning label? \$\endgroup\$
    – Phil Frost
    Jan 31, 2014 at 1:26
  • \$\begingroup\$ I have done this in real life, and there was no visible flicker (at 60Hz) from (I think) a 40W bulb. \$\endgroup\$ Jan 31, 2014 at 1:35
    \$\begingroup\$ They used to sell little diode buttons that fit in a light bulb socket to do just this -- they advertised them as lightbulb lifetime extenders. Here's an Amazon product page for one (though it's sold out) -- looks like it's still in the 1970's era packaging. \$\endgroup\$
    – Johnny
    Jan 31, 2014 at 1:39
  • \$\begingroup\$ Thanks for the response, sounds like a good solution. Is this something you would do to a light bulb in your house? Also could you expand on why I should install many in random orientation, what effect would that have? \$\endgroup\$
    – Dimitris
    Feb 1, 2014 at 13:35
    \$\begingroup\$ To clarify -- the random orientation applies to multiple instances of diodes in series with individual bulbs -- not all together with one bulb. \$\endgroup\$
    – jp314
    Apr 23, 2016 at 4:51
Well, a light bulb is a purely resistive device and if you think a series 2 kohms would fit the bill for reducing its brightness to the right level then it's worth considering using a capacitor instead. To get the same reduction in current you'll probably need between 2 kohms and 3 kohms and the capacitor value would be: -
C = \$\dfrac{1}{2\pi f \cdot 2500}\$
Where f is 50 Hz and 2500 is the nominal impedance. This works out at about 1.3uF.
So, try a 1uF capacitor rated at 250VAC (if that's your AC voltage) and see if it works.
Using a capacitor means it won't generate hardly any self-heat at all.
Also remember to take care when making this modification as it is dangerous.
  • \$\begingroup\$ Andy, could you include a simple schematic of how the resistor and capacitor would be wired to an incandescent bulb in this manner? \$\endgroup\$
    – JYelton
    Jan 31, 2014 at 16:18
  • \$\begingroup\$ @JYelton the capacitor would wire in series with the bulb - is a circuit needed or have I missed something (I do sometimes LOL). OK - there is no resistor... I'm saying use a capacitor instead of the 2kohm resistor!! \$\endgroup\$
    Jan 31, 2014 at 16:24
  • \$\begingroup\$ I just thought it would be useful for the OP or anyone who isn't familiar with it. \$\endgroup\$
    – JYelton
    Jan 31, 2014 at 16:25
  • \$\begingroup\$ Thanks for this, I'll refresh my circuitry knowledge to understand this. How do you think it compares to the answer mentioning using a diode instead? What would you use? \$\endgroup\$
    – Dimitris
    Feb 1, 2014 at 13:39
My application requires reducing the lumens of a 7.5 watt, 120 volt, 60 hertz incandescent indicator bulb to a low and a very low level of illumination. One 3.5 uF polypropylene capacitor (250 VAC) in series with the light bulb reduces its brightness to a low level. Two 3.5 uF polypropylene capacitors in a series reduce the lumens to a very low level. Placing a good ampacity SPST switch across the terminals of one capacitor allows me to toggle the night light indicator bulb between the two low illumination levels. This has become a very satisfactory and inexpensive solution for part of my product line. [For safety's sake, do not use a cheap switch which will arc excessively due to the capacitors stored energy.] J. David Carls
