I want to send the signals from a 3 axis accelerometer (ADXL335) to a PSoC3 via Xbee modules (S2).
What configurations do I need for each Xbees and can I send each of the signals (x, y and z) directly? If yes, then how? Would I need a separate microcontroller to convert analog signals to digital signals, or are the ADCs on the Xbees sufficient to do the job?
  • \$\begingroup\$ It is customary in English to capitalize "I" when referring to yourself. I have edited your question accordingly. \$\endgroup\$ – JYelton Feb 1 '14 at 17:24
The ADXL335 outputs analog data so you can use the ADC on the xbee look at this Guide
