I am a novice to BT so I am looking for some advice. My LPC1314 has a bluetooth module soldered to its UART.
I believe the BT module is a HC-06.
I want to use BT to flash the firmware.bin to the device (later also for debugging). Unfortunately I do not have a manual and I could not get it to work.
- the BT module / connection works (I can remote control the device using an android app)
I can BT scan the device (it shows the MAC address): hcitool scan
I tried different tools to send the file (no luck):
- bluetooth-sendto
- coax-software pybootloader.SerialLoader.py
Any ideas about the right tools to send the firmware.bin file from Linux?
Here my attempt to use the suggested LPC21ISP tool:
mark@ichikawa:~$ sudo rfcomm bind rfcomm0 00:19:MY:MA:xx:yy 1
mark@ichikawa:~$ rfcomm
rfcomm0: 00:19:MY:MA:xx:yy channel 1 clean
mark@ichikawa:~$ ls -l /dev/rfcomm0
crw-rw---- 1 root dialout 216, 0 Feb 3 09:07 /dev/rfcomm0
I resolved the permission issue and lpc21isp stopped complain about the com port...
mark@ichikawa:~$ sudo lpc21isp -control -verify -bin firmware.bin /dev/rfcomm0 115200 12000
Verify after copy RAM to Flash.
lpc21isp version 1.94
File firmware.bin:
loaded...
image size : 1952
Image size : 1952
Synchronizing (ESC to abort)..............................................
............. no answer on '?'
I also pressed the ISP button on the device but still the firmware is not uploaded. I tried using LPC21ISP on Windows7 and it shows me the same synchronizing issue.
