Capacitors in series have identical charges. We can explain how the capacitors end up with identical charge by following a chain reaction of events, in which the charging of each capacitor causes the charging of the next capacitor. We start with capacitor 3 and work upward to capacitor 1. When the battery is first connected to the series of capacitors, it produces charge -q on the bottom plate of capacitor 3. That charge then repels negative charge from the top plate of capacitor 3 (leaving it with charge +q). The repelled negative charge moves to the bottom plate of capacitor 2 (giving it charge -q). That charge on the bottom plate of capacitor 2 then repels negative charge from the top plate of capacitor 2 (leaving it with charge +q) to the bottom plate of capacitor 1 (giving it charge -q). Finally, the charge on the bottom plate of capacitor 1 helps move negative charge from the top plate of capacitor 1 to the battery, leaving that top plate with charge +q.
Why would inducing a charge of +q on one plate cause the other plate to acquire a charge of -q? I get that it would attract electrons from the other side, but the plates aren't the same distance from the electrons, so wouldn't the charge be less than q?
The following diagram might clarify what I mean. Its an explanation of why I think the charges on both plates aren't equal:
Please note I know that you can't use Coloumb's Law with plates. But Coloumb's Law allows superposition, so consider the above diagram to be the sum of all the individual point charges on the plates.
